Shifter assembly
Shifter assembly
Hey has anyone replaced their shifter assembly? On my max the rubber bar that stabilizes the shifter and makes sure that gears mess properly has broken. I can get into all gears expect 2nd smoothly. I know it will just get worse until I replaced the assembly. Does anybody have a cost of the replacement? can I just replace the rubber bar, or does the whole assembly need to be replaced? Instructions are appreciated also. Thanks
When I did the swap I noticed mine had a crack in it, but it doesn't hurt anything. To get it out of the car you must take off the cat. shield and unscrew 4 bolts holding it in as well as disconnect it from the tranny.
thanks for the info!!!! Yea just waiting on the part at this point!!! It is a pain to drive old girl now!!! Reason being is since the rubber brudge has cracked on mine 2nd gear is very difficult to get into. Luckily i dont drive her but on the weekends!! Maxitech what do you think about 1hr job?
yea just got the replacement shifter assembly, will take a picture so others will be able to see. no simple way to replace the rubber bridge it is all one assembly. So the only fix is to swap out entire assembly!!!!
Originally Posted by 3rdgenowner
Did you have to buy the whole assembly or just the rubber bar?
I posted the part number for jkmay01 on another thread he or someone else posted. Although you would think it may be expensive because you have to get it from the dealer its only about $35 or so.
Here is that thread:
http://forums.maxima.org/showthread.php?t=386561
Thanks again Michael, this part is well worth the money!
atriuum
Sep 28, 2015 01:19 PM
