Master window switch bad?
Old Sep 7, 2006 | 04:51 PM
berts689's Avatar
Hey all, well ever since ive had my max the windows have been screwed up, my regulators are fine though....i think. My driver side window rolls down fine but only rolls up 1/2 the time, like ill push the switch up and it wont go but if i wait like a few hours it'll work. My passenger rear window will roll down fine but you cant roll it up from the front but you can roll it up from the back . Oh and also for the passenger front and drivers rear window The directions are reversed, so up is down and down is up(only from the master switch).
Does it sound like the master switch? or a loose ground
Oh and also my left break light is very very dim, even if i replace the bulb its still very dim, almost like its out.loose ground?
Old Sep 7, 2006 | 05:51 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like the master switch to me...
Check your local junkyards or ebay for a replacement...
Old Sep 7, 2006 | 05:55 PM
cmachemer's Avatar
don't even worry about it
I second that; last year when I my car did not accompany me to school first semester we got a really huge rain right before I came back for a work weekend and the switch refused to work, but the keypad still lowered the windows. After "it" (whatever was wet) dried it worked fine again. In your case, with the switches' functions reversed, I'd wager bad switch. Like MyGreenMax94 said, eBay is a good place to look, they can usually be found for ~$30 with shipping.
Old Sep 9, 2006 | 06:21 PM
Sevorg1's Avatar
If you have a multi meter you can take the switch panel out and test for continuity with the meter when pressing the swith up and down this will let you know if it is deff the master switch or not. A cheap meter will work, but if you are going to use it alot and plan on keeping it you will probably end up spending at least 80 bucks. They have unlimited electrical uses though
Old Sep 10, 2006 | 09:26 PM
PovCityHustla's Avatar
I have the same problem. I too have to wait till the thing dries up before it works. I have only had the problem about 4 times in the last year. But a main switch shouldnt cost you too much.. Its also pretty small to pocket..
Old Sep 21, 2006 | 08:06 PM
Pepi's Avatar
a lil late reply but...
yea i had same prob would go down though and only sometimes it went back up.. i took apart the master swith tested the up button with that rubber pad with metal contacts, all i heard was a click click.. so i changed it wand it works perfect.
OT: ok i checked my abs error and its 10 flicks ( Solenoid valve relay ) ok where the hell is the that relay i looked in haynes manual and couldent find it.. only the motor relay.
Old Sep 22, 2006 | 07:45 AM
internetautomar's Avatar
mod or sell?
Originally Posted by Pepi
<snip>
right next to it I believe
t6378tp
Sep 29, 2018 04:27 PM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
