I smell gas....
Old Sep 30, 2006 | 11:48 AM
goon9's Avatar
I smell gas....
Strange... Under heavy acceleration and hard coners I smell gas. Anyone ever resolve a problem like this?
Old Sep 30, 2006 | 02:02 PM
ozzombie13's Avatar
I will eat your children
possible problem with the over flow or vent tube?
maybe this?
Campaign Number: 95V244000 Date: 1995-Dec-15
Component: Fuel System, Gasoline: Storage: Tank Assembly: Filler Pipe And Cap
Defect Summary: IT IS POSSIBLE FOR A MIXTURE OF MUD AND SALT TO GET TRAPPED BETWEEN THE FUEL FILLER TUBE AND WHEEL HOUSING. THE TRAPPED MUD AND SALT CAN RESULT IN CORROSION OF THE FUEL FILLER TUBE AND THE WHEEL HOUSING.
Consequence Summary: SIGNIFICANT CORROSION OF THE FUEL FILLER TUBE MAY RESULT IN FUEL LEAKS WHICH IN THE PRESENCE OF AN IGNITION SOURCE COULD RESULT IN A FIRE. IN ADDITION, THE LEFT REAR SEAT BELT RETRACTOR IS MOUNTED TO THE WHEEL HOUSING AND IN THE EVENT OF SIGNIFICANT CORROSION, AND THE MOUNTING COULD FAIL IN A VEHICLE CRASH.
Corrective Summary: DEALERS WILL INSPECT THESE VEHICLES AND CORRECTIVE ACTION WILL BE TAKEN DEPENDING UPON THE EXTENT OF THE CORROSION.
Old Sep 30, 2006 | 02:25 PM
goon9's Avatar
I'll have to pull the wheel out from there and check a lil better. I did some wheel well repair, and didn't see anything.
I thought it was possible comming from the engine bay. Fuel lines are holding pressure. Anything emission wise that could cause the smell?
Old Sep 30, 2006 | 02:28 PM
Greeny's Avatar
¯\(°_o)/¯
Might be this?...
http://forums.maxima.org/showthread.php?t=364133
Old Sep 30, 2006 | 03:20 PM
goon9's Avatar
That should be it, thnx
Smackasmith
Feb 1, 2016 12:40 AM
homewrecker
Sep 24, 2015 07:01 PM
RWCreative
Sep 21, 2015 11:01 AM
carid
Sep 17, 2015 05:00 AM
Samedi
Aug 13, 2015 04:05 PM
