wheel and tires question...please help
Old Oct 16, 2000 | 10:37 PM
Andrew91SE's Avatar
i want to buy these wheels, they are used. they are 18X8 with 235/40/18 with a 35mm offset...will they fit nicely on my max? any rubbing? will spacers help if so? i have Tokico and Eibach too...thanks!
Old Oct 16, 2000 | 11:39 PM
chris92gxe's Avatar
I have 18x8 on my car but with 225's. I think that extra width might rub a little but I'm not for sure. I'm pretty sure I have that same offset too. You will probably be o.k.
92GXE, touring wing, 18” racing wheels, Port&Polished intake, custom intake, custom yellow interior, racing seats, back seats taken out and replaced with subs and amps, NOS kit, Suspension tech. Lowering springs, custom grille, soon to be custom painted and have the whole engine rebuilt for big shot NOS and custom SC and tranny converted to 5-speed.
Old Oct 17, 2000 | 06:39 PM
ravevious
The most important thing is the weights ....you don't wanna go with MOMO or BBS it's way too heavy for your car. Do a research. i'm not sure about Maxima 91' to 94' but . 235/40/18 and 225/45/17 would be fit perfect for 95' and up. i would recommend you to go with 225/45/17. especially you said that they are used. you don't know the history of the rim, as you know 18" rim is easy get damage. but of course !! 18" is gonna look better depends on how low is your car, too
Old Oct 17, 2000 | 06:51 PM
ryan's Avatar
I'm interested in knowing how you research how a wheel tire combo will fit on our cars because I see some wheels that I like in magz but how do I know if they will fit corectly or not????
RYAN
Old Oct 17, 2000 | 09:39 PM
chris92gxe's Avatar
I know that if you go to a tire place like the tire rack on the internet than they have a link on the site that shows how the aftermarket tire you choose affects your speedometer, and it shows you how much taller and wider it is than stock. Its a pretty cool pegram. I dont think it will help ypu on the offset but it will give you the best size tire to match stock. I think for our maxima's the closest to stock ratio of a 17" tire is a 215/45/17.
Old Oct 25, 2000 | 05:38 PM
vmarques82's Avatar
biggest size without throwing off spedo
Hi guys what is the biggest rim size and tire size i can do opn my 1991 maxima?
Old Oct 25, 2000 | 05:47 PM
chris92gxe's Avatar
The biggest I would go would be an 18" rim. No more a=than 8" wide. For that setup I would go with a 225/40/18 tire. You could get a 235 but I know a guy with 18"'s and he has 235's and they rub when he turns the wheel all the way. My 225's are a lot wider than stock and I think are perfect.
Old Oct 25, 2000 | 05:51 PM
amax935's Avatar
Re: biggest size without throwing off spedo
Tire Rack Recommends 225-45 17, several here have 235-45-17 without problems, but it depends on the offset of the wheels. I went with 16s because I didn't want to get the ride to harsh, or take a chance on trashing a wheel on these outstanding NY roads.
Old Oct 25, 2000 | 07:56 PM
NYCe MaXiMa's Avatar
umm..
The way it works is, the bigger diameter the wheel, the thinner the tire, the less tire there is to absorb the shock when you hit a bump on the road. I popped a cable in a freakin 16 inch tire on my 99 SE 5-spokes and had to get another tire, and those are 215/60/16! NYC roads suck major ***. I will eventually get 17's or possibly 18's, they will look sick! but they probably suck for performance (except handling) road will be rough and because of extra weight and diameter, it will be harder to push it. If the tire rubs on the strut, get some 1/4 inch spacers, but I think the problem will be on turns when u turn the wheel completely. Either way, 18's look hot to death, especially with a dropped car.
I regret getting these 16's
Old Oct 25, 2000 | 08:16 PM
Marcus Cantu
Re: umm..
I have 18" Konig Monsoons with 225/40R18 BFGoodrich tires and I have never really had any problems with rubbing or with the speedometer.
Old Oct 25, 2000 | 09:23 PM
ravevious
Re: Re: umm..
I agree... i never have any problem with my car. I have Quantum Tek 18x8 with 235/40 , the ride is perfect.... Maybe " Chris92gxe's friend did not change his shock...but i'll go with 18" or at least 17" for Maxima 95-99
alahjahwan09
18
Sep 21, 2015 09:12 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
240tomax
Sep 13, 2015 03:28 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
