motor problem
Old Oct 14, 2006 | 04:56 PM
gregoryin07's Avatar
motor problem
I have a situation my max has been running odd. every time i start up the car the motor starts vibrating. Today when i went to go pick someone up the car was had trouble starting. Once the car is warmed up the vibration stops. One other thing when i accelerate hard the check engine light comes on and the car starts vibrating i really need to know whats going on.
Old Oct 14, 2006 | 05:42 PM
Greeny's Avatar
¯\(°_o)/¯
Check the ecu codes...It has most likely stored a code since the cel came on..
Old Oct 14, 2006 | 08:27 PM
probmxstyle's Avatar
Sounds like the exact problem I had when one of my injectors started to go bad
Old Nov 15, 2006 | 12:17 PM
2Legal4Me's Avatar
try running a power balance test on each injector. also try considering the maf sensor also as a prime suspect. depending on what your thread described
its all i can think of. O also try crank angle sensor may be dirty.
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
slowlifer
Sep 8, 2015 05:53 AM
