fog light re-wire help
Old Oct 15, 2006 | 12:50 PM
ArcticDC5's Avatar
So I am following this DIY guide for re-wiring the foglights to come on with your parking lights: http://www.geocities.com/bracecraig/...ewire.html#fog
I went ahead and cut the wire under the relay (red/yellow) taped off the red/yellow going into the harness, and put a wire nut on the red/yellow going into the relay with the new wire. I fished the wire through and tapped into the red/yellow wire on the parking light harness. I tried out the fogs and they don't come on. I tried the red/white wire and still nothing.
I know the foglights work because they worked this morning when I remounted them from the broken mounting bolts I had to re-drill out.
What am I doing wrong??
Edit: Thin wire was used from Alpine speakers and wire taps were not touching any metal. Used thicker wire and works fine.
Old Oct 16, 2006 | 08:49 PM
MAXIMUS G EKSUS's Avatar
Maybe the fog lights are not making ground correctly?
Check your fuses also or spliwire/bad connection, all can have an effect
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
