3rd Gen weird noise, need advice.
Hey, i have a Maxima '94 GXE and damn proud of it. As you all know, winter is coming so i wanna make it run well to avoid making me wish i had the new Altima 07 . . .
Ok, i have several problems.
First, when on idle with the car running, I smell exhaust coming out the driver side. This smell also comes in the car when i don't move and using outdoor venting. When on indoor loop ventilation , it doesn't smell.
Second, when on Drive (D), after hitting 750 RPM or so, i get this deep vibration sound but when i accelerate, it dissapears. It's only when i'm rolling on Drive without giving gas or touching the brakes. NOTE: My front brakes makes noise when braking slightly ( tho the noise is not even comparable!!), could this be related?
Third, which is the last and i'm quite sure i know what's going on, when turning the steering i get those *click* *click* *click* coming from the front passenger side. I guess it's the cardant joint which i changed 2 years ago. Is this usage normal? Could it be caused by a bad suspension? (I think it's the original one :S)
That's about it
Thank you for your incoming help and comments!
That's about it
#1 to me seems to definitely be an exhaust leak, gasses are being sucked in by your fresh air vent.
#2 could be a lot of things, water pump, idler pully bearing other another accessory driven by a belt. both of my cars have something causing a vibration on idle like you're talking about. in the 91 i'm guessing it's the water pump because i've ruled out any of the other accessories. in the 92 it's a the same vibration and fluctuates on and off. i haven't bothered to diagnose it. i wouldn't say it's a "deep" vibration, more of a humming, tuning fork type deal.
cv joints should hold up for longer than 2 years..
Alright, problem #1 uno is quite simple, will get it fix.
Regarding #2, the water pump is spanking new. So are there any options? The timing belt is new also. Problem was the before and after waterpump and timing belt change.
Hectic...
How, and where on earth did you get those!? Hah, are they like hotwheel type cars or trick photography? I need some now!
________
HOMEMADE VAPERIZER
________
Avandia Side Effect
________
HOMEMADE VAPERIZER
________
Avandia Side Effect
The Model Cars:
AHC 3rd Generation 1989-1994 Nissan Maxima SE 1:43 Scale
I found one and It's MINE
________
TOYOTA LAND CRUISER
________
Oregon Medical Marijuana Dispensary
________
TOYOTA LAND CRUISER
________
^^ there you go, they're tough to find. there's 1 left on ebay right now. the seller had 6 up for sale a couple weeks ago and i ended up winning 5 of them. I paid $34 shipped. here's a little video i made http://www.youtube.com/watch?v=QNi3k7IwtCo
SOrry for my ignorance but what's an EGR valve?
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
