installing gauges
Old Oct 26, 2006 | 09:53 AM
SurraTT's Avatar
HR Swap Pioneer
installing gauges
im getting the tripple gauge pod made for 3rd gens
i want some gauges, im lookint at autometer phantom
they are short sweet
oil pressure 52727 59.88
water temp 5737 46.96
volt 5791 39.98
i get 20% off at advance they are full electrical
i just need help on how to hook them up
oil, i guess i can tap into the oil press sendin unit
water temp, tap into chts??
volt, run strait to batt
Old Oct 26, 2006 | 11:16 AM
internetautomar's Avatar
mod or sell?
volt 5791 39.98
they come with their own sending units (except volt) that have to be used
Old Oct 26, 2006 | 11:22 AM
AAP12's Avatar
Well if your getting 20% you must be an employee. I would check and see if those are special order or not. If they are special order you are not supposed to get a discount. Thats what swayed my decision to get the procomp ultra light.
Old Oct 26, 2006 | 03:19 PM
speedfreak4996's Avatar
i work for advance here on the eastcoast and i would personally order from keystone. employees get items at cost, which is most of the time better than the advance 20% off garbage.
plus keystone has a big fat catalog with all sorts of goodies and gauges
im picking up a 92 se tommorow, im excited!!
Old Oct 26, 2006 | 03:35 PM
89blackse's Avatar
"and falling like a rock"
Auto or (crosses finger) Manual?
Old Oct 26, 2006 | 03:36 PM
mod or sell?
huh?
you mean if you order from keystone as an advanced auto employee you get it at advanced's cost? but if you order from advance's special order dept you only get 20% off?
eh, I'll find out the whole story hopefully eventually
Old Oct 26, 2006 | 06:26 PM
SurraTT's Avatar
HR Swap Pioneer
i know they come with their own units, so i have to find a spot to put another oil pressure unit?? and water???
yes i work there,
yes they are FDO but we still get disc
keystone we dont get anything, is that ur store?? or in the handbook??
cuz i found some stuff i want but they told me no disc at all
Old Oct 28, 2006 | 06:44 PM
SurraTT's Avatar
HR Swap Pioneer
hey, so i got my gauges and pod
i understand how they work, its just the oil pressure should i use a T adapter? will this still give accurate readings??
the water temp sensor where can i put it without taking the exsiting one out????????
i have to use the sensors that came with the gauges?? i cant just hook up the 1 wire????
Old Oct 28, 2006 | 08:41 PM
mod or sell?
you have to use the sending units that came with the gauges.
you will need to "T" them inot the existing setup, it will not affect the reading to any major degree
Old Oct 29, 2006 | 05:32 AM
SurraTT's Avatar
HR Swap Pioneer
i undstand the T for oil pressure, but not for water temp, its a longer sensor and the t is not deep
Old Oct 29, 2006 | 05:49 AM
mod or sell?
but you also need to make sure the threading is the same as the cars
most gauges come in SAE rather than metric fittings
Old Oct 29, 2006 | 01:27 PM
huh?
yeah advance can be a bit of a rip off. Regardless of what you order through keystone, you always get it at advance cost. Through the special order department or (pdq) its always marked up and even with the 20 percent discount, its never as cheap as keystone..
Old Oct 29, 2006 | 03:11 PM
SurraTT's Avatar
HR Swap Pioneer
the threads are right, i got a new oil psi unit for mt car and its the same as what came with the gauge
pdq was good, i got all 3 gauges for $120 thats cheeper than i could find on the net anywhere
Old Oct 30, 2006 | 02:35 PM
SurraTT's Avatar
HR Swap Pioneer
ok turns out i needed a oil pressure adapter, and i wont be able to use both the light and gauge o well
the coolent is a big problem
#1 the snesor i got will not go in its 1/8 NPT they dont make a adapter to make it m12 1.25 so idk wtf to do, i would like to put it in a diff place anyway so i can keep the stock gauge working
where could i put it?? isent there a extra place on the lower intake????
Old Oct 30, 2006 | 03:35 PM
ColdSHO's Avatar
i monted my water temp sender in an adapter that requires u to cut a 2 inch section of rad hose out and replace it with the adapter.
mines kind of like this
http://cgi.ebay.com/ebaymotors/34MM-...spagenameZWDVW
i dont have the gauge hooked up all the way yet, the manual states the sender should be grounded, how did u guys do urs?
97_GXE
20
Sep 17, 2015 08:12 PM
BrandonCause
Sep 14, 2015 10:41 PM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
asianstyle
Sep 10, 2015 11:30 AM
