sunroof drain exit point?
Old Nov 29, 2006 | 06:16 PM
blackmax42's Avatar
I have wet rugs... I've determined that it is (I think) the sunroof drain hose on the passenger's side. Is that supposed to actually directly exit the car? i.e drain to the outside? If so, my body filler work may have accidently blocked this which explains it. Please tell.. does anyone have an actual exit point for this drain hose (pass. side) Thanks to all...
Old Nov 29, 2006 | 06:29 PM
Greeny's Avatar
¯\(°_o)/¯
http://forums.maxima.org/showthread.php?t=361188
Old Nov 30, 2006 | 09:44 AM
blackmax42's Avatar
Well when I pulled the drain hose up from the passenger side, it seems to be feeding into the rocker panel. I must have covered up whatever drain there origionally was with body filler. I suppose now I'll have to create a new drain exit behind the wheel so water can flow directly out. Thanks for the reference.
Old Dec 2, 2006 | 06:36 PM
JRS89MAX's Avatar
I know my drainage is rotted up. Causing water to come in.theres a sticky here about it somewhere.
bigdogsteve
Jan 31, 2018 04:18 PM
gigabyte
Jan 6, 2017 06:05 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
