now that the cold weather rolled in....
Old Dec 7, 2006 | 01:58 PM
nForce's Avatar
The Computer Guy
I am just wondering if this is normal or not. I know engines do not perform great under cold conditions but wow this is horrible. So I have been driven mostly city(stop go stop go traffic kind of driving) and my trips are no more then 8miles I have only be getting 215 miles off one tank of gas, that to me is awful. I usually get about 350 off a tank. Could cold weather really cause this much of a change? I always put mid grade ( 89 octane) in my max and do regular tune ups ( plugs, wires, oil change, clean air intake, all of that good stuff). I don’t know I am just curious is anyone else getting bad gas mileage like this? Only thing I can think of is maybe a exhaust leak? I have WSP Y pipe, high flow cat, ngk o2 sensor, remus muffler. Also I do notice at startup the engine revs to 1k then quickly drops to 300 or 400 acting like its going to stall but quickly catches its self any suggestions?
Thanks guys....
Old Dec 7, 2006 | 02:11 PM
I30tman's Avatar
It might be the winter grade gas, I know gas id made up for diff states, but in Ca I see a little diff with it.
Old Dec 7, 2006 | 02:41 PM
N34JZ's Avatar
Needs non-Maxima Friends
I know my max ran best in freezing weather, only probably was getting the tires to stick to the asphalt.
Old Dec 7, 2006 | 04:16 PM
Greeny's Avatar
¯\(°_o)/¯
Mine runs much better in the cold weather[i.e. VAARROOOMMM!]
But yeah,it does use more gas in the winter due to it taking much longer to get into closed loop+letting it sit-n-warm up in the morning+putting it to the floor more..
Old Dec 7, 2006 | 04:21 PM
elusivemax93's Avatar
dude do a tune up also change ur fuel filter and oils and check tire pressure see if that isnt the reason why your getting bad mileage
Old Dec 7, 2006 | 05:15 PM
89badmaxse's Avatar
in florida we do not have to worry about this changing tires for the season or different gas grades
Old Dec 7, 2006 | 06:07 PM
nForce's Avatar
The Computer Guy
well my tires are 38lbs all around, fuel injects, plugs, wires, filter, distibutor, cap, rotor, alternator, radiator, starter, battery, timming belt, water pump, o2 sensor, pcv valve, erg valve, y-pipe, hi flow cat, muffler, brakes, struts and more have all be cleaned or replaced over past yr. so idk...
I do know that my tranny SUCKS it slips and takes forever to engage in a gear idk if this is wats causing my mpg to go down. I do know that sometimes the tranny doesnt even unlock into high gear untill 20 mins after drivin it on highway. It basically gets stuck and for me to go 70mph its at about 3000 rpms compared to 2100 rpms under normal conditions.
Old Dec 7, 2006 | 06:18 PM
Greeny's Avatar
¯\(°_o)/¯
Fix the transmission dude..
Old Dec 7, 2006 | 06:24 PM
nForce's Avatar
The Computer Guy
well I really want to do the 5-speed swap an .org member has basically everything I need atleast I think so but I have no idea wat exactly I need.
This is wat he would sell me....
97k tranny
clutch/brake pedal
m/c
lines(will need to be reflared or replaced)
shift linkage
trim around shifter
Is this everything needed? I plan on gettin new M/C / Clutch / Flywheel
Old Dec 8, 2006 | 06:45 AM
crabapple's Avatar
Man! Busy and expensive year for the max.
I also would love to do the 5-speed swap but everybody I know that could help me thinks I'm crazy, "why do you want to make it a standard! What a hassle". Nobody understands me! lol.
Cold is also a prob with my tranny - but really only extreme cold. Like this morning it was in the low 20's and until it warms up (4-5 minutes driving) it's totally non-responsive - revs high in 1st but barely goes, and the whole car will vibrate if you try to give it too much gas once it shifts into 2nd/3rd. But like I said, once it warms up it's smooth sailing. I've thought about draining the ATF and refilling. The color is dark but it doesn't smell burnt or anything. More than likely I'll just keep letting it warm up 5-10 minutes in the morning and drive it really easy and wait for spring.
Old Dec 8, 2006 | 07:05 AM
nForce's Avatar
The Computer Guy
does anyone have or know of a exact parts list for the swap?
I have a guy at shop that will do it for 500 but I need to get him every part/wire/bolt/washer.
thanks guys
tarun900
19
Dec 20, 2021 06:57 PM
TKHanson
Nov 24, 2018 01:39 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
