Will 18x9 with a +40mm offset Fit?
Old Jan 4, 2007 | 06:55 PM
  #41
shavedmax's Avatar
Originally Posted by therealgoon9
Just some pics.
Fronts are hitting the strut, just the tire. I still would like it 20mm off the strut to maintain what little steering radious I have.
Didn't have time to check the rears.
20 mm is almost an inch, if you use a smaller spacer you dont have to cut anything up...................less work.......................more happy....................
but now you need some juice or air
Old Jan 4, 2007 | 08:13 PM
  #42
maxima_kid's Avatar
Is this without spacers?
Old Jan 5, 2007 | 04:38 AM
  #43
goon9's Avatar
Yes12312321
Old Jan 5, 2007 | 05:36 PM
  #44
maxima_kid's Avatar
What size spacers are you using? It dosnt stick out too much. Looks good.
Old Jan 5, 2007 | 05:48 PM
  #45
Michael's Avatar
Back in a 3rd Gen.
hmm, it dosnt stick out too much. Thats nice
no but he stated it hits the strut so he needs spacers which will stick it out a little more depending on the size of the spacer.
If it does he will reshape the fenders though which will tuck it all back in.
Old Jan 6, 2007 | 03:51 AM
  #46
Pervis Anathema's Avatar
Those wheels are pure sex.
Old Jan 6, 2007 | 05:30 AM
  #47
tripleGmax's Avatar
damnn that looks good. i bet in a turning contest though you would lose to a dump truck....
edit: is that a donor max in the background?
Old Jan 6, 2007 | 12:00 PM
  #48
goon9's Avatar
Yup, #2 donor car. lol.
I'm TRYing to keep my turn radious... Trying. I'm eaither going to have to roll the fenders and bo ok, our rebuild them and be great. Would like to go wide body!
Anyone wanna tell me how much air I need in my tires?
Old Jan 7, 2007 | 11:26 AM
  #49
Jbr8k's Avatar
Goon, I need to see the rears mounted!!
Old Jan 7, 2007 | 03:11 PM
  #50
Michael's Avatar
Back in a 3rd Gen.
same as any other I assume...around 35psi. Check the tires recommendations.
Old Jan 7, 2007 | 03:57 PM
  #51
goon9's Avatar
Ok, wasn't sure. I always put 32 in regular 15" tires. The tire doesn't say anything, just not to exeed 40 when setting the bead.
Old Jan 12, 2007 | 06:13 PM
  #52
Spadezz's Avatar
this guy wants to sell me some rims off his mustang, he said they are about 10 1/4 wide, what would i need to do to make them fit? or is it possible at all?
Old Jan 12, 2007 | 07:57 PM
  #53
Michael's Avatar
Back in a 3rd Gen.
You can make them fit but they will stick WAY out of the fenders. In order for them to look good you would have to do extensive body work and if you are asking how to make something fit then I assume you do not have the skill to make them work.
I would pass on them if I were you.
Old Jan 12, 2007 | 08:35 PM
  #54
goon9's Avatar
Thats way too wide for sure. Even for a 4th gen I would imagine.
Old Jan 13, 2007 | 08:32 PM
  #55
maxima_kid's Avatar
Yea, 8.5" is pushing it without rolling the fenders outward ...
Old Jan 22, 2007 | 08:31 PM
  #56
maxima_kid's Avatar
Hows are the wheels coming? I also have a fender roller if anyone wants to rent ...
Old Jan 23, 2007 | 02:28 PM
  #57
goon9's Avatar
I would defintly like to rent it if you were near by.... I gotta pay taxes this year... So it's on hold.
Old Jan 24, 2007 | 12:07 AM
  #58
elusivemax93's Avatar
yeah bro how are the rims and fittament isusse coming along?
Old Jan 24, 2007 | 04:29 AM
  #59
goon9's Avatar
So far I defenitly need 25mm rear spacers. The current studs arn't even long enough to get a lug on. And it looks like I only need to roll the rear fenders.
Old Jan 24, 2007 | 06:32 AM
  #60
try getting the nismo studs i beleave they make a longer stud for ther maxima not exactly sure but you should check into that call your local nissan dealership and ask the parts people if they have any longer studs for the max.
Old Jan 24, 2007 | 02:40 PM
  #61
goon9's Avatar
When I buy spacers they come with studs. The Fronts will have longer studs. The rears will have studs already in them.
Old Jan 25, 2007 | 06:47 AM
  #62
o okz my bad didnt know lol. anyways yeah nismo makes a 50 mm long stud and also a 60 mm long stud for all makes and models nissan vehicles that they sell as there legacy R tune line.
Old Jan 26, 2007 | 07:13 AM
  #63
JCZ33's Avatar
And whats a good tires size?
18X9 would fit with some fender rolling.
for 8" wide I would use a 235 or 245 wide.
for a 9" wide, 245 would be too stretched, I would go 255 wide.
Old Jan 26, 2007 | 07:17 AM
  #64
JCZ33's Avatar
Do you have more pictures of your car? I think your E36 conversion is th best I have seen.
MORE PICS please.
Old Jan 26, 2007 | 07:21 AM
  #65
JCZ33's Avatar
Originally Posted by Jbr8k
If you're looking at the rear they should fit with spacers but won't tuck, Now the front might be a different story.
I'm running 8.5" all around with 225/40 and I'm right on the egde in the front.(235/40 18 will not fit in the front without fender mods)
DUDE! Can I see some more pictures of your car? Thank you.
Old Jan 26, 2007 | 07:22 AM
  #66
JCZ33's Avatar
actually the wheels use a standard hole and you put hub centric rings into the wheel so you have more options and will fit a wider range of cars.
You can get the correct hub centric rings for the Maxima that fit those wheels so it will be easier to get a Maxima spacer.
Or you can take the hub centric ring thats in there now and get a spacer that has the outer ring for the center of the wheel and inner of the Maxima.
The best thing would be to get the correct hub ring for the wheel that fits the maxima and then just get hub centric spacers for the Maxima. That way if you ever wanted to get other wheels you can do it easier.
www.ICHIBA.com makes the spacers you need to be hub centric
Old Jan 26, 2007 | 07:24 AM
  #67
JCZ33's Avatar
Well the fronts only have a 1/4 betwean the rim and strut.
So I think a 1" spacer will do for the front.
The rears hit the strut with 1/4" to go. Probubly 1.5" spacer is needed.
ICHIBA makes 25mm spacers that bolt onto the hub, then you could get 5, 10, 15 or 20 with the included longer studs to add to the 25mm hub kit and make any width you wanted.
Old Jan 26, 2007 | 07:25 AM
  #68
JCZ33's Avatar
here is a tip for you that you might have thought of already. Take a bunch of washers and put on the wheel studs (obviously the same amount on each stud) until you get the correct spacing. Measure the washer stack and get that size spacer custom made. That way you may actually fit it without having to do a LOT of fender work.
SWEET IDEA.
Old Jan 26, 2007 | 07:27 AM
  #69
tripleGmax's Avatar
245 would rub on a 8" wide rim if you are lowered. in fact i was lowered 1.7inches and the 235 rubbed in the back. i had to roll my fenders for it. 255 would call for some major modification.
Old Jan 26, 2007 | 07:31 AM
  #70
JCZ33's Avatar
Did they rub with your G wheels? That looks so nice BTW.
My 97 COBRA wheels had 245/45/17s on them w/o rubbing lowered on EIBACHS(more back spacing - 17X8). If I kept those wheels I would have had to gone with a 235 when I switched to INTRAX.
Old Jan 26, 2007 | 07:34 AM
  #71
JCZ33's Avatar
ICHIBA spacers
ICHIBA USA Aluminum Hubcentric Wheel Spacers www.ichibausa.com
5MM Aluminum Wheel Spacers $59
10MM Aluminum Wheel Spacers $99 ***New Item***
15MM Aluminum Wheel Spacers $99
20MM Aluminum Wheel Spacers $109
25MM Aluminum Wheel Spacers $129
Old Jan 26, 2007 | 01:25 PM
  #72
goon9's Avatar
Thats the brand I'm going with when the time comes.
BTW, did u you know you can edit your post. So you don't have... 8 seperate post?
There are some older pics here. http://forums.maxima.org/showthread.php?t=445808&page=2 It's long since been reconstructed but you get the idea.
The tires I have are 245 40 18 They are stretched a little, not even close to be unsafe.
Old Jan 26, 2007 | 02:32 PM
  #73
JCZ33's Avatar
I don't know how to do the "post" thing. Teach me.
Cool.
I found this for the rear: you said you needed 1.5", wewll these would be 1.25", close...
http://cgi.ebay.com/ebaymotors/5X114...QQcmdZViewItem
Old Jan 26, 2007 | 03:50 PM
  #74
goon9's Avatar
Cool.
25mm= about an inch.
THose won't work because they are not hub centric. Although I emailed the seller and told him they arn't. But claims they are exactly what is pictured and that that are hub centric... He's an idiot.
If you look in the last post you made. You can see a little button that says Edit.
Old Jan 26, 2007 | 04:29 PM
  #75
JCZ33's Avatar
Respect your Elders! HAHA!
I used to go by "Mr. Rose" but I've changed e-mails and had to re-register.
Seriously the ICHIBAs are not hub centric?!!! WOW! That's news to me, but I never had any. My MAXIMA sported H&R. Let me think... There was another brand that made them flat, and the hub centric rings were extra.
Oh yeah... "PROJECT KICS" that's it...
http://www.mackinindustries.com/wm/kics/kics.html
"Direct from Japan, the KICS wide thread spacers are used to bring out the wheels of your car outer to give aggressive look and close the space gap. The KICS wide thread spacers are also used to clear spacing between your big brake kit from the wheels. These spacers come with new studs already installed with all necessary hardware. Available in 15mm, 20mm, 25mm, and 30mm for most popular Japanese vehicle applications (1.5mm / 1.25mm)."
FOUND THEM HERE FOR $115...
http://www.istoreparts.com/kics-whee...3-p-14469.html
Of course you probably know all this stuff.
Hey. I noticed you are in North Atlanta. If you need some wrenching done, or an extra brain on the job, let me know. I'm local to yah.
Old Jan 26, 2007 | 05:25 PM
  #76
goon9's Avatar
That ebay link wasn't hub centric.
The ICHIBAs are.
If they don't have a ring in the middle, they are not.
Old Jan 26, 2007 | 06:48 PM
  #77
JCZ33's Avatar
The ICHIBAs are.
Oh, I misunderstood, so the ICHIBAs are good to go then. OK.
Old Jan 27, 2007 | 06:28 PM
  #78
maxima_kid's Avatar
I think youre in luck. I bought a pair of 25mm hub centric wheel spacers for a maxima a few months back to push out the rear wheels but with the offset im getting with the new wheels, I wont be able to use them anymore. Ive tried finding the same exact ones I bought to show you but it seems like he doesnt sell them for maximas anymore. I paid about $110 after tax but if youre interested, just looking to break even. Id take $100 shipped. Let me know
http://cgi.ebay.com/ebaymotors/5x114...79406466QQrdZ1
Old Feb 17, 2007 | 06:57 PM
  #79
maxima_kid's Avatar
any pic update?
Old Feb 17, 2007 | 07:05 PM
  #80
goon9's Avatar
any pic update?
nope, sorry. kills me looking at then in my den.
