Hood Project!
Old Dec 21, 2006 | 09:49 PM
Pearl93VE's Avatar
I can has?
Hood Project!
So my hood was previously bondo'd and was cracking horribly in the center and chipping bad (paint was coming off like snake skin) so I grinded it all down (lost about a half inch where the bondo was) all the way to bare metal. Anyway, It was my first time using bondo, actually... just my first time doing body work all together, but after about 5 hours I'm thinking it looks pretty good, ready to be painted tomorrow. Just thought I'd share as I'm no longer a body work virgin anymore! Yay...
pics: ( I should have taken "before" to show you had bad it was...
I'll take more when I get it re-painted....
________
IPAD ACCESSORIES
Old Dec 22, 2006 | 04:56 AM
internetautomar's Avatar
mod or sell?
bondo on a hood
Old Dec 22, 2006 | 07:27 AM
goon9's Avatar
Looking at it, I think you'll find you sanded too much after you paint it.
Old Dec 22, 2006 | 07:33 AM
Michael's Avatar
Back in a 3rd Gen.
good job for your first try...a couple of things though...
1. it will crack again because 1/2" it too thick for bondo. You should bang it out first.
2. They make flexible filler which would be best on a hood.
3. Those spots that you filled will show up under the paint as low spots because of the way you filled them. When doing filler work its best to feather edge it farther past the bad spot then prime and block sand to make sure there are no low spots. With you just having the low spots filled like you do it will be lower than the rest of the hood. You may not think so but you will see after you get the paint on.
Not trying to be negative but just trying to share my experiences with you.
Old Dec 22, 2006 | 07:59 AM
Pearl93VE's Avatar
I can has?
Well the reason it is such a big area is because I bondo'd on top of previous paint about 2 inches past the low part itself, then feathered it in and sanded with 320 grit sand paper wrapped around a rubber block. so even though the bondo portruded past the existing level of the hood at one time, it's all pretty level now that I sanded it afterwards.
________
EXPERT INSURANCE
Old Dec 22, 2006 | 08:28 AM
Michael's Avatar
Back in a 3rd Gen.
ok...I am not talking about the big part. Just get it painted and see what you did wrong so you can learn from it. Either way I am sure it will look much better than big cracks.
Edit...here is an example of what I am talking about. See all the spots that look like big bondo spots? They are actually very small, very shallow dings but looking at it you would thing I used a LOT of filler and the dents were huge. Its just how you feather it. The little small spots were chip repairs. Now after this step I primed it and block sanded it to make sure I had everything level and didnt have any low spots (the primer helps transition the filler work to the rest of the paint).
as it is with yours you just filled in the small dings but didnt feather past it and when you paint it you will see those spots as low spots.
one last thing before the pic. I painted this hood black and it was perfect. Looked brand new with no low or high spots.
I am just telling you this stuff for your benefit. I made the same mistake you did when I first tried this stuff and learned from it.
Old Dec 22, 2006 | 08:44 AM
Jeff92se's Avatar
I'm needing a caw
Too bad you don't live near me. I'd basicly give you my old hood. It's not perfect but it's 10x better than what you are starting out with
Old Dec 22, 2006 | 08:53 AM
Pearl93VE's Avatar
I can has?
Yeah, I see what you mean now, and I appreciate your input, better to learn from others more experienced. My dad gave me a little bit of help near the beginning, but for the most part I was on my own. I'm thinking of rattle canning just the part I did to see how bad it dips, or if I have any rolls. But yeah, Hopefully a cheap remedy from buying a new hood, and It looked HORRIBLE before. I couldn't stand it.
________
Paxil attorneys
Old Dec 22, 2006 | 02:34 PM
Gun5's Avatar
takes practice, rolls in the metal suck VERY hard to get rid of because u have to raise areas around it exactly to get rid of them getting it really close works it will be 99% better then how it was before
Old Dec 25, 2006 | 07:57 PM
saxytothemaxima's Avatar
haha. how do you fix this?
<br>
Old Dec 25, 2006 | 08:29 PM
Pearl93VE's Avatar
I can has?
<br>
Ummmm..... salvage yard time ?
________
Wellbutrin class action lawsuit
Old Dec 25, 2006 | 08:35 PM
haha. i went to one and they were going to charge me 80$ for a half finished hood. it looked like it was wrecked.
Old Dec 26, 2006 | 05:33 AM
Greeny's Avatar
¯\(°_o)/¯
http://www.sandwauto.com/
This yard is in lithonia,they have several hoods to choose from,all for $75..
Old Dec 26, 2006 | 05:46 AM
goon9's Avatar
Considering you'll spend probubly $40-50 on materials, over 8 hours and possibly still not have the hood look right. It would benefit to buy one in good shape. Did you try pull-a-part in Doraville? They shouldn't charge more than 50, and I KNOW they have a few good hoods.
Edit, there is a Pull-A-Part in conely and norcross. Hoods are 28.28
Old Dec 26, 2006 | 07:45 AM
Matt93SE's Avatar
STFU n00b!
IMO, throw it away and get a new hood. that much damage and bondo on it will show back up quickly and just as ugly as before. been there, done that.
for something as large and flexible as a hood, you don't want to use much, if any, Bondo on it. thin layers to fix paint chips like Michael showed you are fine... but anything more than about 1/8" will eventually crack and show... The hood flexes a LOT, and bondo is a pretty brittle solid once it completely cures. you can see where I'm going with this....
for the time and effort you've spent on it, it's a great lesson in how to learn bodywork, but you'd be better off buying a junkyard hood, then sanding and repainting it.
Old Dec 26, 2006 | 09:21 PM
thankyou a whole lot!!!!!
Old Dec 27, 2006 | 07:32 AM
«§»Craig B«§»'s Avatar
Yeah, pull-a-part is great and very cheap. I am home for the holidays (Duluth) and got some parts for my prelude from there. I saw a couple 3rd gens, but didn't look too close since I didn't need anything. Check out http://www.pullapart.com . They even have online inventory and price list. It costs $1 to get in and then you do the work yourself so you may want to bring a friend if you're picking up a hood. Also, you may want to take your stock hood off before you go so that you'll have somewhere to put the new one
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
