torque number for ST front stabilizer bar
Old Dec 28, 2006 | 06:49 PM
bvtran's Avatar
94c Big Max
anyone here still have their ST front stabilizer bar manual. Could you please tell me what is the torque number (ft lb) for where the bar connects to the control arm? I remembered it was around 18 ft lbs but I could be wrong. Thanks.
Old Dec 29, 2006 | 02:47 AM
rimaximaman's Avatar
I just tightened up mine till it was nice & tight.....
Old Dec 29, 2006 | 06:17 AM
gdmaxse's Avatar
tighten it so the bushings bulge out a little bit
Old Dec 29, 2006 | 06:49 AM
DanNY's Avatar
Ad·min·is·tra·tor
quoted for truth
Old Dec 29, 2006 | 11:06 PM
bvtran's Avatar
94c Big Max
I just called ST today and they told me it should be the same as factory setting? But the thread seems a bit wider than stock though. It doesn't quiet make sense. Oh well.
Old Dec 31, 2006 | 06:32 AM
Pervis Anathema's Avatar
Dude, seriously, tighten until it slightly bulges the bushings. We are not lying to you.
Old Dec 31, 2006 | 12:00 PM
Matt93SE's Avatar
STFU n00b!
read the effin manual yourself then.
http://blehmco.com/faq/st_sways/
Old Dec 31, 2006 | 05:23 PM
dafiremaster's Avatar
on a quick sidenote is the ST front sway bar bigger than OEM?
Old Dec 31, 2006 | 05:48 PM
bvtran's Avatar
94c Big Max
THANKS, MATT!!!!
18 ft-lbs, that's all I needed.
Old Dec 31, 2006 | 05:50 PM
bvtran's Avatar
94c Big Max
Stock has two nuts, the smaller one takes 15ft lbs, while the bigger one takes.... I can't remembered. So yes, the stock is relatively smaller. Either way, stock sucks. My stocks sway bar/control arm joint broke off when I made a sharp turn 3 years ago. It scared the daylight out of me.
Old Dec 31, 2006 | 05:57 PM
bvtran's Avatar
94c Big Max
Humm.... I guess you got lucky but if it got over-torqued, then it'll screw up your alignment... Last time, it screwed up my camber angle on one wheel. I guess it must be because I over torqued it to 24ft lbs.
Old Jan 1, 2007 | 08:48 AM
Matt93SE's Avatar
STFU n00b!
if you screwed up your camber from tightening the sway bar bushings an extra 5 lb, then you've got something SERIOUSLY wrong with your suspension.
homeyclaus
Sep 3, 2015 06:15 PM
Stagnet04
Aug 30, 2015 07:30 AM
jerrod99_se-l
Aug 22, 2015 04:14 AM
Team STILLEN
Aug 10, 2015 04:29 PM
