bad idel and take off still help fast!!!please
so my car is driving me crazy i have replaced 3 fuel injectors/spark plug wires/ 02 sensor/new y pipe and cat/ cap and rotor are basically new and so are spark plugs. and i am still getting a very rough idle sometimes to the point were i feel like it is going to die especially if i put on my rear defrost. and i am getting very bad sputtering and very slow take offs up until around 3000rpm. now i have posted with this problem a couple of months ago and when i replaced the fuel injectors it stopped and now that last two weeks it just started again. any one have any suggestions? i am tired of throwing money into this thing. I'm a college student i can not afford to...please help?
ive cleaned that twice....also replaced 2 radiator hoses brake lines all struts controller arm driver side bearing cv shaft and the list goes on...i just need it to get me to school and back....hour drive there and back every day
I concur with the other fuel injectors, especially if your symptoms went away completely and now the car has the identical problem.
I had a bad one replaced and two weeks later another went bad. That's when I just got all of them replaced.
check your vaccum hoses to the egr and pcv valves they may be dry and cracked. $3.00 for 2ft of hose, needle nose pliers, and the 1994 maxima service manual from the autozone website to see what they look like (see the last sticky for the gen 3 max).
So it stopped for awhile then started doing it again? The process of elimination says there's either crud in the system, or the injectors weren't seated well. Also, I've read some stuff here about rebuilt injectors having problems sometimes.
Have you checked all electrical connectors under the hood, when replacing the injectors, you may have moved some bad connectors a bit which made them work for a while, but now they have gone bad again. It's a bit of a long shot, but cleaning up connectors is easy and cheap.
sorry guys i have been at work. my fuel filter was changed about a year and a half ago. the injectors were brand new from napa for 80 bucks about 3 months ago or so... i have not checked the hoses yet ill do that tomorrow it was cold at 8 this morning when i was changing the wires.i cleaned all the injector connectors very well when i changed the fuel injectors so they should still be ok..my altinater(sp?) belt is making a little bit of noise but i did not think that can make that bad of a sputter.ill look into buying new hoses i know i need a new one on my fuel rail it leaks here and there but i did not want to do that until i needed to change a fuel injector again which might be the case here. i can do it, it just sucks and takes for ever....after doing it 3 times i have it all memorized.
Originally Posted by Dirt Rich
My max basically did the same thing, found a broken wire at the ECCS. Changed it, and runs like a champ.
I got a mysterious broken wire running from my cat supporting bolt. I have no ideas where that goes. It doesn't look like it has any conductor inside, just a stupid wire.... is that it?
i got it all fixed and it ran fine and as of yesterday it wont start...it ether wines really loud or clicks...tried jumping it and nothing....went to u haul to rent a toe dolly and the dolly was to high and the maxima would not fit the bumper hit the ramps before the wheels did and of coarse no refunds so im out 50 bucks
Originally Posted by bvtran
got any pictures or diagram of where this could possibly located?
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
