oxygen sensor socket
Old Jan 6, 2007 | 04:44 AM
redwood_usa's Avatar
I have a vg engine. All the sockets I can find in the store are 22mm, but the maxima has a 17 mm nut on the socket. Any clues where I can pick up a 17 mm socket.
Part 2. I am replacing the sensor. any harm ( is it easy) in just breaking off the outside cover (that shinny little tube that sticks out) and cutting the wires and using a regular 17 mm socket ?
Old Jan 6, 2007 | 08:26 AM
DanNY's Avatar
Ad·min·is·tra·tor
get a 17mm closed end box wrench..cut the wire..sleeve the wrench over the sensor and pull/push.
Old Jan 6, 2007 | 10:10 AM
bvtran's Avatar
94c Big Max
don't even bother with getting fancy specialized socket at the store. just cut the wire and grab a deep 17mm (4in long) and racket will do it. make sure you disconnected your negative terminal first before you do this.
Old Jan 6, 2007 | 04:11 PM
internetautomar's Avatar
mod or sell?
Get a 17mm Deep socket and cut a groove in the side of it.
Old Jan 18, 2007 | 10:44 AM
morides4chefs's Avatar
morides4chefs
try open end wrench.there's a special socket w/a slit in it to feed the wires that you can buy.
Old Jan 18, 2007 | 11:29 AM
Pearl93VE's Avatar
I can has?
After 2 trips to the auto parts store and back looking for o2 sockets and something that might fit, or a deep enough socket to at least work... I ended up using one of these puppies!
________
Zx14 Vs Hayabusa
Old Jan 18, 2007 | 02:57 PM
DanNY's Avatar
Ad·min·is·tra·tor
that's the open/close end wrench that i speak of.
Old Jan 18, 2007 | 02:58 PM
DanNY's Avatar
Ad·min·is·tra·tor
standard open end will just strip the O2 causing you even more pain.
a crows foot wrench is better..but if you're going to replace it anyway use the closed end of the combo wrench and push/pull as much as you can and it won't strip the O2 (assuming that you're working with decent wrenches).
Old Jan 18, 2007 | 03:24 PM
Cliff Clavin's Avatar
Way out West
I got a set of those ratcheting wrenches. They work wonders.
you can buy just one 17 mm, though:
Craftman 17mm ratcheting wrench
Harbor Freight might be cheaper.
Old Jan 18, 2007 | 04:31 PM
thanks everybody - I already changed the sensor - unless you need the posts to qualify for posting.
Old Jan 19, 2007 | 06:05 AM
DanNY's Avatar
Ad·min·is·tra·tor
we like to talk ...but this thread will (hopefully) help someone else out that has the same problem.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
