Wires through the firewall??
Old Jan 13, 2007 | 01:17 PM
TWINTRBO's Avatar
Where can I pass the alarm siren cable through the firewall? I dont want to drill if possible. Thanks.
Old Jan 13, 2007 | 06:21 PM
goon9's Avatar
Same place all the other wires go through.
Take out your driver wheel, remove splash gaurd. Look up in the fender and you'll see alot of wires going through a rubber piece. Stick a long screw driver through it and feed the needed wire back through.
Old Jan 13, 2007 | 06:38 PM
Matt93SE's Avatar
STFU n00b!
Old Jan 13, 2007 | 07:49 PM
VEvolution's Avatar
I miss my VE
Maybe tape the wire to a long antenna and poke ur way through that rubber from underneath the dash?
Old Jan 13, 2007 | 10:28 PM
Matt93SE's Avatar
STFU n00b!
if it's as small as you say it is, you can also use the hood release cable grommet. it's much thinner and easier to puncture. I've used it with up to 4awg wire before..
Old Jan 15, 2007 | 03:07 PM
TWINTRBO's Avatar
cool, thanks guys. I'll get out there tomorrow and take care of the siren and then I'll be done with this alarm install finally!
Old Jan 15, 2007 | 03:20 PM
goon9's Avatar
I wish I was smart enough to wire up an alarm. Hope my doesn't break so Craige doesn't need to fly down here to fix it.
Old Jan 15, 2007 | 08:41 PM
VEvolution's Avatar
I miss my VE
It's really easy.. I practiced like on 3 cars at work with a bit of help, and I pretty much got it down tight. Hardest part is finding the correct colors that are going to the ignition, but most alarms have a website that tells you which is which for each car.
Old Jan 16, 2007 | 07:39 AM
Matt93SE's Avatar
STFU n00b!
maxima wiring stuff...
http://blehmco.com/faq/wiring_info/
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
