Testing injectors
Testing injectors
Can I pull the connectors off the injectors( at least 5 of 6) with the plenum on or do I need to take the plenum off to pull the connectors to test the resistance. VG30 engine
Also how can I check to make sure my connectors are fine.
Also - whats the difference between the dot color on the injectors and is there some list of which cars had which. my car was built in May 93. I bet they were not randomly putting in different injectors.
i'm surprised this thread isn't already flooded with the standard "USE THE SEARCH FUNCTION" comments.
in any case, i don't have exact dates of production but it seems that earlier 3rd gens had blue dots and newer the black dots. i've read on this board that the 2 differ in some calibration - though nothing specific mentioned - and in the connector design.
that being said, it has always been recommended to never mix dot colors - though again, i've never read why not to do so.
regarding the connectors, they are interchangeable. a blue dot injector will fit into a black dot connector and vice versa. the fact that replacement (not reman) injectors do not differentiate blue or black dot application part numbers is evidence enough of this fact.
from what i've seen, the connectors differ in the way the keep tension on the injector. the blues have a metal spring type interlock and i believe the black has a more common plastic mechanism.
testing:
pulling the connectors is a perfectly acceptable way to note which injector is/isn't doing it's job and to check resistance as well. it's also a great time to clean the connectors and throught some dielectric grease in there.
there is a test port on the vg in the front, driver side corner of the engine - but i am not familiar with the ve. which motor do you have?
hope this was useful
testing:
[QUOTE=DaWifey's90]i'm surprised this thread isn't already flooded with the standard "USE THE SEARCH FUNCTION" comments.
I have run the search function (always do before posting) but theres nothing specific to the questions I asked ( at least not in the first 5 pages of googles list of answers).
Whats a good connector cleaner. I have a few connectors that are caked with hard with buildup and cant get it off with normal electrical cleaner.
they just grab whatever is easiest, sometimes it would be the rail with with yellow dots, sometimes green dots. they all got mixed together when they made the batches.
the dots probably indicate flow rate tolerance of flow rates
you don't know much about production lines do you?
as far as cleaning, i just used a metal pick to scrape off the corrosion and then generously applied some dielectric and that yielded a great deal of improvement.
don't sweat the "you don't know much about production lines" comment. with the amount of engineering that goes into a vehicle, it would be laughable to suggest that a line worker just puts whatever is closest especially by a company as reputable as nissan. typical american mentality of what's acceptable to do though - i've seen it at ford and gm...could be why japan is where all the reliable cars come from.
Originally Posted by DaWifey's90
to clarify, i meant maxima.org's search function - it's nice to support a resource of such information that you benefit from.
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
