Throttle cleaning
Old Jan 19, 2007 | 11:54 AM
redwood_usa's Avatar
Throttle cleaning
I am getting ready to clean the throttle body. All I can see are two bolts holding the elbow that goes to the throttle body. Besides the hoses and the electrical are these the only two bolts that need to be removed?
Old Jan 19, 2007 | 11:57 AM
bvtran's Avatar
94c Big Max
I think there are 4 not 2. it's been a while since I've done it.
you probably will not see a whole lot differences just by cleaning the throttle but you'll definitely feel it once you cleaned your plenum.
Old Jan 19, 2007 | 01:41 PM
DanNY's Avatar
Ad·min·is·tra·tor
nope..
there's 3...2 that you see on the flange and the 3rd bolt holds down the spark plug wire bracket/holder. same size..just a little longer.
you *might* have to get a new gasket for that elbow...but sometimes you can reuse it from the elbow.
once open you'll see the dual butterfly opening. spray your cleaner in...you might want to replace the two vacume lines under the TB. there are 2 holes (one in each intake port) that your cleaner will probably end up draining into so pull those lines off the TB before you start cleaning.
oh and try to avoid using the straw...they don't stay on the can and when you spray it usually shoots into the engine.
Old Jan 19, 2007 | 01:44 PM
bvtran's Avatar
94c Big Max
make sure you get new gaskets for each joint....chances are they already dried up and will tear as you dissemble it. I know I had to replace all of mines.
Old Jan 19, 2007 | 01:57 PM
Greeny's Avatar
¯\(°_o)/¯
Speaking from experience?
I shot one of them into a cylinder some years ago,that was loads of fun..
Old Jan 19, 2007 | 02:06 PM
DanNY's Avatar
Ad·min·is·tra·tor
not into the engine...i always do a test spray away from the car to check to make sure the straw won't shoot off. seen it fly off too many times...so i just said eff it and left the straw off.
Old Jan 19, 2007 | 02:12 PM
Pacecar78_vette's Avatar
Sorry that this is not on the subject, and I would create a new thread if I could, but it says I cannot because I dont have enough posts. I dont know too much about maximas to give advice, so Im unsure of how to get posts...but oh well.
Anyway I just purchased an 88 maxima and my electronic speedometer and the trip meter works intermititly. Is this a common issue with maximas? Or is there something in particular to check. I see that the speedometer cable runs up to a module on the firewall and everything is connected, and i seperated the connections and cleaned them, but still the same problem.
Sorry, not trying to hijack the thread
Old Jan 19, 2007 | 02:28 PM
I did a search at NAPA and Autozone for throttle body gasket and came up with nothing for the vg30 engine. Any idea Where I can buy or what it is called alternatively.
Old Jan 19, 2007 | 02:37 PM
DanNY's Avatar
Ad·min·is·tra·tor
might be a dealer part.
Old Jan 19, 2007 | 02:38 PM
DanNY's Avatar
Ad·min·is·tra·tor
might be the speed sensor in the tranny.
also the 88 is a 2nd gen car. might be better answers from the 2nd gen section instead of the 3rd gen section.
BTW welcome to the org.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
