Coolant leak
Old Jan 21, 2007 | 03:36 PM
decus's Avatar
Coolant leak
I've got a VG30E with two coolant leaks....not small drips, but not pouring out either.
The first one I tracked down to the front side middle welsh/freeze/core (whatever you want to call them) plug. The other plugs on the front look good.
The second leak....well, I have NFI where it is coming from. The drips come out on the rear side of the engine between the engine and the transmission....I can track it up beside the oil pan but thats about it....too much crap in the way.
I'm thinking another welsh plug...but I can only see the front one on that side and it looks good....is there anything else that could be leaking coolant in that area?
I tried some Bar's Leaks and it fixed the front welsh plug leak but not the other leak......which is a PITA because I can fix the front one without too much trouble......its just this other leak thats driving me nuts.
What would be the next step? Start pulling the engine out to get a look at the rear welsh plugs?
Old Jan 21, 2007 | 05:04 PM
internetautomar's Avatar
mod or sell?
it could be weeping from the head gasket or an intake manifold gasket.
try some UV dye to track it down
Old Jan 21, 2007 | 11:21 PM
decus's Avatar
How would I go about checking the head / intake gaskets? I'm trying to track down some UV dye, but the local auto place didn't have anything.
I've taken the oil filter bracket and another bracket out and can see a little bit clearer where the leak is coming from (looking up from the bottom, tranny at the top of pic, oil pan to the bottom left):
As soon as you add coolant to the radiator it starts leaking out that hole in the middle of the pic.....car does not have to be on and there is no oil in the coolant.
Anyone have ideas? From the top of the engine I can't find any wet spots...
Old Jan 22, 2007 | 07:35 AM
Greeny's Avatar
¯\(°_o)/¯
My guess judging by the pic,one of the rear freeze plugs may be leaking..
Old Jan 22, 2007 | 01:16 PM
CyMax's Avatar
I too have a leak, nut it's on the belt end of the motor, I'm guessing the water pump is going to pot. Any ideas?
That UV dye refered to earlier is really cool stuff for finding leaks, give it a try, sure worked wonders finding an AC leak in my wifes old civic.
Old Jan 22, 2007 | 01:27 PM
Greeny's Avatar
¯\(°_o)/¯
Just replace the water pump Cyrus..
BTW..
Old Jan 22, 2007 | 02:46 PM
decus's Avatar
Thanks for the pic MyGreenMax94, I was wondering where the other plugs were.
So whats going to be the easiest way to get to them......drop the tranny?
Old Jan 22, 2007 | 02:52 PM
Greeny's Avatar
¯\(°_o)/¯
Yup...
Old Jan 22, 2007 | 04:24 PM
decus's Avatar
Does anyone have a guide to removing the auto tranny? I'm looking through the FSM and can't see anything thats going to help me.
Old Jan 22, 2007 | 06:24 PM
CyMax's Avatar
BTW..
Brilliant as always
How are ya??
Old Jan 22, 2007 | 06:29 PM
Greeny's Avatar
¯\(°_o)/¯
Brilliant as always
How are ya??
meh..
Old Jan 22, 2007 | 06:30 PM
bvtran's Avatar
94c Big Max
yeah how do you guys remove an auto tranny? that thing doesn't look like it weight lesser than 100lbs. Do we need a cheery picker for that kinda works?
Old Jan 22, 2007 | 06:32 PM
CyMax's Avatar
No offense but judging by your question your awnser is.... Take the car to a mechanic.
Old Jan 22, 2007 | 06:39 PM
Greeny's Avatar
¯\(°_o)/¯
Dropping a transmission has many steps involved,and too many variables for a write up on it to be feasable..
Best thing for you to do would to buy some good quality tools/jack..then have at it..If you get stuck,someone on here may be able to help you out ..
Or bust out the credit card and take it to a mechanic..
Old Jan 24, 2007 | 03:19 AM
decus's Avatar
I've found a couple of links that should help.
http://www.cardomain.com/ride/749143/2 is one of the better ones.......doesn't seem that hard....just have to clear out the garage
Old Feb 7, 2007 | 10:02 AM
jdMx-3Kid's Avatar
UM ... this guy is talking about a cherry picker for a tranny.... um ...ok.... but anyway.... im trying to post my own thread and its really fruitraiting cuz i cant but... my maxima is over heating on me i have looked over and over i have no coolant leaks but the fans are not tuning on ... is there a sensor i should be messing with i know for my mx-3 all i have to do it disconnect the sensor and both of my fans turn on ... i was just wondering if there is anything similar to that on the maxima
Old Feb 7, 2007 | 10:13 AM
Alex_V
Yea I'm going to use a cherry picker/engine lift next time I drop the max's tranny. Much better then using a jack since it cant fall off the jack.
Also make sure the max's cooling system is bleed properly. Jack up the front end until the rear bumper hits the ground and run the car for 20min or so with the radiator cap off and the heater on full blast. Add coolant as needed.
~Alex
Old Feb 7, 2007 | 10:23 AM
jdMx-3Kid's Avatar
....thats is good stuff man.... never thought about that....
..... please tell me you are not serious about the picker.....
Old Feb 7, 2007 | 10:27 AM
Greeny's Avatar
¯\(°_o)/¯
You do not have to use a engine hoist to remove the transmission,just support the rear of the engine with a jack...
The engine mounts are still in place when removing the trans,so the engine will not fall down...
Old Feb 7, 2007 | 10:29 AM
jdMx-3Kid's Avatar
i understand that.... i just wassent sure if YOU were kidding... i dont think ive ever used or heard of anyone using a cherry picker for a tranny... but then in again... i only know mazda...
Old Feb 7, 2007 | 12:19 PM
92 Max's Avatar
I though this was cool. If you already have a hydraulic floor jack.
http://www.northerntool.com/webapp/w...70_19795_19795
Old Feb 7, 2007 | 01:16 PM
decus's Avatar
Well turns out it was one of those welsh plugs...the right one in the pic from MyGreenMax94.
All fixed now...thanks all.....few more little problems and the max will be like new
Old Feb 7, 2007 | 03:16 PM
MrGone's Avatar
couple of different methods. I've done write ups for the 5spds in the past, the auto's should be able to use most of the steps and shortcuts.
lots of Cheerios
or Wheaties, lots of Wheaties.
Old Feb 7, 2007 | 05:43 PM
mod or sell?
you'll still need something up top to support the engine on most cars
Old Feb 7, 2007 | 06:26 PM
bvtran's Avatar
94c Big Max
Thanks for the useless answer. If I ever need to take it to the mech, I will do so but I ask how to do it. Secondly, I don't have any problem with my tranny. I asked cuz I was curious.
http://www.harborfreight.com/cpi/cta...emnumber=39178
slightly lesser than $100 shipped to your door.
Old Feb 7, 2007 | 06:28 PM
bvtran's Avatar
94c Big Max
good instruction using a crane-like picker.
Old Feb 8, 2007 | 08:12 AM
jdMx-3Kid's Avatar
dude chill out....any way just to let you guys know... the question i asked about unplugging that sensor.... okay well if you follow the radiator hose line on left (passenger side) it goes into the block... theres is like a whitish sensor there.... unplug and WHOALA!!!!!! 2 FANS ON AT THE SAME TIME. But anyway thanks for all the help fellas.
Old Feb 11, 2007 | 09:21 PM
LvR's Avatar
LvR
Indeed, and the ECU has no clue what is happening on the engine and as a result your car will drive like XXXX and fuel consumption will approach zero at great speed.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
foodmanry
Sep 24, 2015 12:02 PM
Hdnseek
Sep 9, 2015 05:55 AM
