Best Lowering Products
Old Jan 25, 2007 | 10:28 AM
heresmymind
Well taxes will be in soon. and I am getting a large chunk of change back...
I love to drive sporty and aggressive 75% of the time
what is the best combo for springs/struts?
Please post all opinions on all combos!
Old Jan 25, 2007 | 10:52 AM
Josh's Avatar
you donated you should know this: http://forums.maxima.org/search.php
The general consensus is Eibach and Koni. This exact same thread has been posted dozens of time and it comes down to those two if you want to enjoy the ride and have struts that hold up.
Old Jan 25, 2007 | 12:04 PM
elusivemax93's Avatar
I second josh's motion and agree eibach/koni.
Old Jan 25, 2007 | 03:17 PM
505max94se's Avatar
I third josh's motion and agree eibach/koni.
Old Jan 25, 2007 | 03:21 PM
Maximahappy22's Avatar
I fourth that motion and agree seeing as i have eibach/koni and the are amazing, not to harsh but hold the road amazingly, and i can out handle my friends rsx on most turns...
Old Jan 25, 2007 | 05:59 PM
jlars205's Avatar
I know that's the consensus for the best products, but is there anything good out there if my budget doesn't allow for koni shocks?
Old Jan 25, 2007 | 06:45 PM
Greeny's Avatar
¯\(°_o)/¯
I just installed B&G springs/Tokico struts....Me Likey!!
Old Jan 25, 2007 | 06:55 PM
JCZ33's Avatar
INTRAX or SPRINT / TOKICO with Suspension Techniques sway bars...
But nothing, and I mean nothing beats a new set of bushings or urethane bushings. Start with bushings and sway bars.
Old Jan 25, 2007 | 07:11 PM
andy21's Avatar
i got eibach/tokico and ive had them for about 2 or 3 years...
great handling and not too bad of a ride for about $500 total when i got them...no complaints so far
but yea like everyones saying go with eibach/koni if u got the cash for it
Old Jan 25, 2007 | 07:14 PM
JCZ33's Avatar
I had Eibach / Tokico prior to my INTRAX Tokico, and the difference was night and day. The Eibachs are very harsh compared to the INTRAX, and honestly I had the EIBACHS for 3 years, and INTRAX for four years.
INTRAX was a 10, EIBACH, ahhhh 6.3 in my book on any road, straight or twisted.
Old Jan 25, 2007 | 10:23 PM
see there is one slight problem you never had the eibach koni set up so how can u actually say it was the springs when u where already and still are running the tokico???
Old Jan 26, 2007 | 12:26 AM
505max94se's Avatar
If you wan't to lower your car and not have to worry about replacing your struts in 1-2 yrs then buy the Koni's other wise Tokicos (not to mention how much better the ride is with Koni's vs. Tokicos).
If you want your car to handle good then buy Eibach's. If you want it to look nice (even F-R drop) and LOW then buy Intrax.
As far as anything else... I won't recommend anything else, so make a wise decision.
Old Jan 26, 2007 | 12:28 AM
505max94se's Avatar
BTW, I'm not biased. I've had Maxima's with other suspension setups as well.
Old Jan 26, 2007 | 06:59 AM
JCZ33's Avatar
I had new EIBACH(fresh out of box) / new KONI(fresh out of box) on another car for 4 years. The KONIs are fine the EIBACHS are not.
each set up I had on the maxima was...
1st - brand NEW TOKICO(fresh out of box) w/new(fresh out of box) EIBACHs for about 3 years.
then...
2nd - brand NEW TOKICO(fresh out of box) w/new(fresh out of box) INTRAX for about three years.
I now run TOKICO D-Specs with SPRINT on my Z.
I would say that the best, best, best setup for the MAXIMA would be the KONI's with INTRAX or SPRINT but never got a chance to do that.
Old Jan 26, 2007 | 08:45 AM
JCZ33's Avatar
Actually regardless of what setups I had, the best modification of any of then were the Poly Bushings greased beyond recognition. The Poly bushings always made any set up perform as the products were intended. Untill I added in the Poly factor, each set had it's draw back. So all of those set ups were subject to suspect performance with the original rubber / slush bushings.
Old Jan 26, 2007 | 10:47 AM
Jbr8k's Avatar
They make a huge difference.
Old Jan 26, 2007 | 10:50 AM
Pearl93VE's Avatar
I can has?
then...
That's fresh man...
________
New Mexico Marijuana Dispensary
Old Jan 26, 2007 | 11:26 AM
JCZ33's Avatar
More pictures of your car out there?
Old Jan 26, 2007 | 11:31 AM
JCZ33's Avatar
Originally Posted by 94maxshima
That's fresh man...
So fresh and so clean.
MaxLvr21
Oct 17, 2015 12:11 PM
JonBlz
Oct 5, 2015 06:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
