What to Check Speedo Aint working??
Well I got the timing fixed dumbass me had the 3 and 5 wires mixed up
pulled it out in to the street and burned the tires off power is back now i need to get the speedo working so the tranny will shift i checked the wires and it looks good (BTW I took it off the stock tranny in car and put it on a junkyard tranny i rebuilt - new clutches/band)
Speed sensor on top of the tranny, near the oil filter(drivers side), it has a bolt, 10mm.
Loosen the bolt and check the wire connections. If that one is not it, then there is almost one identical to is directly under it, nearest to the drivers side drive axel.
What happens is this; the press fitted top loosens and wiggles out so the spinning gear does not make connection with the electrical parts inside and wholla... no speedo.
Both of them used to loosen out about every 6 months, I just politely tapped them back into place with a rubber mallet.
2 speed sensors ??? umm is it an auto or manuel your talking about cuz ive pulled both the auto and manuel tranny before and both only had one speed sensor so where are you coming up with the second speed sensor???
5spd has two, I included two in my descript, not knowing about the auto having two or not.
Either way my 15 years of MAXIMA experience, and 10years or MAXIMA.ORG ecperience always has room for improvement.
Mental note: auto tranny has one sensor
Originally Posted by Gun5
hmm i just pushed it in by hand its kinda sticking up like it has alittle more to go probably the issue ill double check it all in the day time... hopefully the car shifts good if it does i woulda successfully rebuilt my first tranny
Seems like one could make a l type bracket to hold it in permantely.
I think courtesy NISSAN wanted $100 for the top one, and about the same for the bottom one(5spd).
Originally Posted by MyGreenMax94
The 3rd gen 5 speed and/or automatic has ONE speed sensor,not 2
When I called Courtesy NISSAN several years ago, they kept telling me that there was only one. I insisted that there was one underneanth, so the manager got on the phone and he spent an hour with me looking through the parts diagrams. He finally found it, and sure enough it was speedo related. The part was so rare that it had to be ordered from Japan, and Courtesy did not even know how much to charge me for it untill they got a quote on it.
Needless to say that small part that looks like the top one, only smaller, plugs into the transmission and affects speedo somehow.
What is the part called? You got me.
I'm not trying to be right here, just trying to share the right info.
There is one on the bottom of the tranny that is a 5speed, and easily overlooked. It will make the tach go Crazy, and disable the speed sensor.
The part you are referring to is called the neutral position switch...It has nothing to do with the speedometer..
Well; when I replaced it the entire tach / speedo combo came back to life, so what does it do Professor? Thanks for the Diagram BTW, I needed it for reference.
The switch controls the backup lights on a 5 speed,on a automatic it also prevents the car from starting in any of the drive gears...
The only problems i have heard of on here from a faulty neutral position switch is it sometimes will blow fuel pump fuse when you attempt to put the car in 1st or 2nd gear.This is on the manual transmissions...
IIRC,org member "Hectic" had this issue with his car...
It is a multi-function switch...
Whatever the issue, I don't have the car any more, but it is good for reference. I am looking for a 92-94 SE 5spd.
ah2002
Mar 9, 2016 01:42 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kjm900r
Aug 5, 2015 07:14 AM
