CHTS Cylinder Head Temp Sensor Replacement
Old Jan 25, 2007 | 06:45 PM
4togrfr's Avatar
I know the CHTS on my 90 is bad. Classic failure symptoms including ECU code 13. My question is where is it! Haynes says behind the timing belt cover (for 88 and 89 doesn't address 90), but in changing two timing belts on this car, I can't for the life of me recall a sensor in there! Before I tear it open again, I'd like to be sure thats where the CHTS is.
Nissan gave me a part 22630-51E02 which looks like a typical temperature sensor, with a fuel injector looking plug. I've also read a post (in gen 1&2 forum) to replace the harness when replacing the CHTS. Is this necessary or reccomended? How about a p/n for the harness? Thanks.
Mike
Old Jan 25, 2007 | 06:54 PM
Greeny's Avatar
¯\(°_o)/¯
Old Jan 25, 2007 | 07:10 PM
4togrfr's Avatar
This is definately not the part Nissan gave me to replace. The sensor your photo points to on my engine has a single wire attached to it... This is the sensor I have to replace:
Old Jan 25, 2007 | 07:23 PM
Greeny's Avatar
¯\(°_o)/¯
The pic i gave you is the chts...The pic you have looks like the coolant temp sensor,this sensor is is shown in the pic i posted,it is opposite the chts with the yellow plug...
Old Jan 25, 2007 | 07:34 PM
4togrfr's Avatar
That's kind of what I was affraid of! Do you happen to know the correct p/n for the CHTS? I'm not finding anything at Google or Courtesy's website.
Old Jan 25, 2007 | 07:46 PM
Greeny's Avatar
¯\(°_o)/¯
Go to the dealership for the part,it should not be to expensive..
Old Jan 25, 2007 | 08:09 PM
4togrfr's Avatar
Yah, that's what I did the first time.... I'm curious now though, my Hanyes manual points to the same part your photo does and it calls it a coolant temperature sending unit (ie. the one that sends the temp to the temp gauge). I think I'll take a stab at the other one first...
Old Jan 26, 2007 | 11:15 AM
Alex_V
Buy the other one and replace both. Its cheap, and you have to drain coolant to do either one, so its best to spend the extra $12 and do both at once.
The single wire sensor is for the gauge, and the 2 wire is for the computer.
~Alex
vingodine
45
May 21, 2016 12:46 PM
raffivegas
Aug 23, 2015 09:54 PM
FlaMark
Aug 21, 2015 11:06 AM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
