Fast!!! UDP install help...
Old Jan 26, 2007 | 06:08 PM
Maximahappy22's Avatar
I am installing my UDP right now and i cant seem to get the 27mm bolt off the drive pully itself, i have tried kicking it and pulling it. so what way does the bolt come off, do i pull towards the front of the car, or do i push toward the back of the car?
also is i necesary to remove the belts before i try to undo the pulley?
Any help is great, thanks
Alex
Old Jan 26, 2007 | 06:43 PM
«§»Craig B«§»'s Avatar
right tighty, lefty loosey
it's a standard threaded bolt so counterclockwise
You'll probably need a big breaker bar though to help out since it's on there pretty tight. If you have access to an impact wrench, that'd definitely help.
You dont need to take off the belts yet but you will eventually when you take off the pulley obviously.
Old Jan 26, 2007 | 06:46 PM
JCZ33's Avatar
^ Three cheers for Craig B!!!
Guess who?
Old Jan 26, 2007 | 07:15 PM
Thanks man, i know about the righty tighty lefty loosey but i wasnt sure and i was thinking about it from the bottom, so left would be to the back of the car...
Thanks for clearing that up though...
Lets go see if i have the man strength to get this bastard off.
Old Jan 26, 2007 | 07:34 PM
bvtran's Avatar
94c Big Max
you need an impact wrench to get it off, don't waste your time or you need to wedge the fly wheel... waste of efforts, just get an impact wrench... any will do it, even a cheapo impact wrench that uses car battery will do just fine.
Old Jan 26, 2007 | 07:54 PM
Matt93SE's Avatar
STFU n00b!
I've even sometimes been able to pop it loose using a long breaker bar and just bumping the starter. let the breaker bar whack against the control arm and it'll pop loose.
not the best method though.. I've made it work when my impact wouldn't break the crank bolt loose.
the other thing you can do is drive the car to a local tire shop or mechanic and have them break it loose using an impact, then just tighten it by hand so you can drivce it home.
and yes, you need to remove all of the belts in order to remove the pulley. not to break the bolt loose, but definitely to remove the pulley.
Old Jan 26, 2007 | 09:07 PM
CyMax's Avatar
Not to post ***** but I needed the impact gun when I installed a UDP. I dont know about the one mentioned above, I used an air gun set pretty high. It did come right off but hey.
Old Jan 26, 2007 | 11:16 PM
Impact wrench is for loosers, i used my hydrolic jack to pry the breaker bar up thus getting the bolt loose, then i just twisted it off... Install went well aside from the 2 hours driving around buying stuff, and breaking my spark plug while setting the timing at 10:15pm when all the auto stores are closed
Anyway thanks for the help guys, but no need for an impact wrench. can't wait to get the car running again
Alex
Old Jan 27, 2007 | 01:40 AM
Greeny's Avatar
¯\(°_o)/¯
Alex
No,they are for mechanics..
Old Jan 27, 2007 | 10:04 AM
ColombianMax's Avatar
pwned by a greenman muahahaha!
Old Jan 27, 2007 | 10:55 AM
Guess who?
I was confused for a second, but the cardomain gave it away Nice Z!!
Old Jan 27, 2007 | 12:06 PM
Matt93SE's Avatar
STFU n00b!
Guess who?
Howdy, Mistah Rose! We're all still here, lurking in the corners.
Old Jan 27, 2007 | 01:26 PM
JCZ33's Avatar
CB, I still read your website just for fun! Man I must be a serious DORK.
But I'm happy about that!
Still rollin the MAXIMA with those EIBACHs?
Old Jan 27, 2007 | 01:29 PM
JCZ33's Avatar
Mey Matt, the "3rd Gen MAXIMA god"; Has any one made you a crown yet?
Sincerly; You are the man, come on up to Georiga and I'll make yah PANCAKES!
I noticed you tore the dash out and put your dash guts in the dishwasher. Why? HAHA!
When I get my MAXIMA back I'll be buying those lateral links+trailing arms, RSTB and the front chassi brace from yah.
Enjoy the weekend!
Old Jan 27, 2007 | 03:37 PM
Matt93SE's Avatar
STFU n00b!
No crown yet... and I wouldn't call myself a god... guru maybe, but no god..
the dash came out because the heater core was leaking. yuck. that was a nightmare I'll not soon forget.
and unfortunately it's going to have to all come back out eventually.
I didn't get something right on the AC ductwork and it leaks water around the cowl intake. pass floorboard is always wet after it rains.
Old Jan 27, 2007 | 04:00 PM
Greeny's Avatar
¯\(°_o)/¯
No crown yet..
Here's your crown matt..
Old Jan 27, 2007 | 05:50 PM
internetautomar's Avatar
mod or sell?
you already took a pic of him with his crown ??
J/P
Old Jan 27, 2007 | 06:40 PM
Matt93SE's Avatar
STFU n00b!
HA!!
That's close.. but I have more hair than that.
bumpypickle
Sep 20, 2015 08:22 AM
pears
Sep 18, 2015 05:25 AM
Maxxx10
Sep 13, 2015 03:16 PM
