possible new source for exhaust studs
Old Jan 30, 2007 | 01:58 PM
DaWifey's90's Avatar
what can my max do for me
been shopping for a while for exhasut studs and through most fo the searches on this board i don't recall anyone mentioning a supply house like grainger....soooo......
http://www.grainger.com/Grainger/wwg...mId=1613557978
if the link doesn't work, just go to www.grainger.com and select fasteners, then "threaded rod and studs" and spec out an M8 x 1.25 50mm...the stainless one goes for less than $2 a piece.
the price drops to less than half of that if you spec out a hex head bolt!!!
sorry if this is a repost
Old Jan 30, 2007 | 02:01 PM
Greeny's Avatar
¯\(°_o)/¯
Why not get the 300zx turbo studs from the dealership?
Old Jan 30, 2007 | 02:13 PM
rimaximaman's Avatar
Are the 300zx turbo studs better? Will they fit a 3.0 VG?
Old Jan 30, 2007 | 02:25 PM
Greeny's Avatar
¯\(°_o)/¯
Yes they are/Yes they will...
Old Jan 30, 2007 | 02:40 PM
What year 300zx turbo, do I get them from?
Old Jan 30, 2007 | 02:57 PM
Greeny's Avatar
¯\(°_o)/¯
Z31 [84-89]studs are the ones you need..
Old Jan 30, 2007 | 03:55 PM
do you have part numbers? what kind of pricing are they going for? what about them makes them better? are they stronger than 304 stainless?
Old Jan 30, 2007 | 03:57 PM
Alex_V
I thought it was the Z32 (90-96) that were stronger and were the only ones that worked? Plus I think all the VG studs have been superseded (sp) by now any way.
They are made of a much better material and thus wont break. I wouldn't trust any other stud, except a 10mm that was properly tapped out. Id just call the dealer and ask for them, shouldn't be an issue.
~Alex
Old Jan 30, 2007 | 04:22 PM
Greeny's Avatar
¯\(°_o)/¯
Info on the studs and replacement...
http://forums.maxima.org/showthread.php?t=468282
http://forums.maxima.org/oldthread.php?t=392645
Old Jan 30, 2007 | 05:47 PM
internetautomar's Avatar
mod or sell?
I was going to use the ones off my CTS-V
Old Jan 30, 2007 | 05:51 PM
Thanks for the information, my rear manifold has a minor tick, not bad at all, when it gets warm you don't even hear it, later down the road if it gets loud, I will tackle that job, till then, it's not a problem at all.....
Old Jan 30, 2007 | 05:52 PM
What the heck is a CTS-V (LOL)!!!
Old Jan 30, 2007 | 09:30 PM
Originally Posted by MyGreenMax94
i've read through those threads during some of my research but still couldn't find any quantification re why they are better and in what way they are stronger.
so now here's the rub, is the point ot get the strongest replacement available (ARPs) or the least expensive (grainger). since no one seems to have specs on the nissan parts, it's a bit difficult to make this call. seems like lots of trouble for otherwise benign hardware - then again, i don't want to do this job again and i don't want to pay more than i have to
Old Jan 30, 2007 | 11:20 PM
bvtran's Avatar
94c Big Max
man if I were you I wouldn't make a big deal out of it man. If it broke and your engine is mad old, get on ebay get a new manifold....just go the shop and have them frigging weld the whole crap on for around $50-100 or have a friend with a welder do it for you for free.
ColombianMax's Avatar
dude, dont even bother going anywhere other than the dealer and dont bother asking for 300zx studs like GREENY said (sorry greeny just wanted to pick on ya) Just ask for normal maxima studs, z31 studs are the same as the maximas as nissan superceeded (spelling) them due to their weak design.
Here's what I got from the dealer for my 1993 GXE, I believe they're the same as yours and notice how they say TURBO on them as it is. I requested for the parts guy (member from Chicago Maxima Club) at the dealer to look up studs for 300zx turbo and they're the same part number.
Old Jan 31, 2007 | 03:37 AM
Greeny's Avatar
¯\(°_o)/¯
[IMG]http://i24.photobucket.com/albums/c42/ColombianMax/12-14-06_1209.jpg[/IMG
Oh,no problem,i didn't know the part#'s had been supeceeded...
Old Jan 31, 2007 | 06:52 AM
Cliff Clavin's Avatar
Way out West
It still might be a good idea to be sure, since some dealers might have NOS (new old stock) on hand with the older version. Jeff did mine just two years ago and I know there were still two part numbers.
Old Jan 31, 2007 | 11:54 AM
Hectic's Avatar
"Amateurs don't use nitrous oxide. I've seen the way you drive, you've got a heavy foot....You'll blow yourself to pieces"
Old Jan 31, 2007 | 12:31 PM
maxitech's Avatar
Well, if you don't know...I sure as heck wouldn't, seeing as neither of us own one...
Old Feb 4, 2007 | 05:47 PM
if i do go the right angle drill route and try this nightmare repair myself, is it possible to do so without removing the manifold?
the broken bolts seem to be only on the tranny side of the motor. i figure if i don't try to remove the bolts that aren't broken i don't have to risk breaking them. i know there may be gasket issues but those matters notwithstanding, is this a feasible approach?
Old Feb 4, 2007 | 05:52 PM
Greeny's Avatar
¯\(°_o)/¯
Just take the time to remove the manifold,in the end it will probably save you time..
Old Feb 4, 2007 | 10:23 PM
Its funny cuz its true so I'm gonna agree with greeny, look at that guy with the control arm..he tried saving time and he ended up spending over a month working on it and still hasnt finished. Do it right and just do it once
Old Feb 4, 2007 | 10:33 PM
Tom's Avatar
Tom
FYI - So you all know, the new studs can break too.
I replaced mine at 75K (with the TURBO studs), then again at 179K miles (TURBO studs again).
It's probably not much of an issue for most people as I can't imagine most people on this forum driving their 3rd gen for another 100K miles.
Old Feb 5, 2007 | 04:23 AM
goon9's Avatar
I got mine from ace hardware for under 7 bucks. They are hardened so I thought I'd give em a try. Works just fine.
Old Feb 5, 2007 | 04:52 AM
The Max's Avatar
~Alex
Z32 are stronger because they're actually of a larger diameter as well, so you can forget about using them in our heads. As for the VG studs being superceded, perhaps with something of better manufacture, but they're not obsolete. You ask for a Z31 turbo exhaust stud, that's exactly what you get. I have noticed, however, that the crush rings for our exhaust manifolds to the collectors are now made out of stainless steel instead of the old copper. I got a couple when I was putting the motor back in mine and was pleasantly surprised to come across them.
Old Feb 5, 2007 | 02:15 PM
DanNY's Avatar
Ad·min·is·tra·tor
weld what exactly?
kinda tough to weld alum to cast iron..no?
aw11power
Oct 10, 2021 04:57 AM
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
