installing clutch for 5speed swap
Old Feb 2, 2007 | 06:22 PM
  #41
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by Nmax92
i already got the 5 speed axles. I'm gonna get them put on monday coming. (keeping my fingers crossed)
MyGreenMax94 - do you recall if how many harnesses are supposed to be connected after the swap.
I did the rewire so the car can start and the reverse lights. and for the cruise control. am I missing anything?
I don't know about all the harness stuff,i've never done a 5 speed swap,but i am quite sure the auto/manual axles are different...So swap them out..
Old Feb 3, 2007 | 05:27 PM
  #42
internetautomar's Avatar
mod or sell?
The VG uses the same axles whether it is A/T or M/T.
Old Feb 3, 2007 | 05:31 PM
  #43
Greeny's Avatar
¯\(°_o)/¯
Ooops...I thought they were different...
Old Feb 3, 2007 | 06:00 PM
  #44
mod or sell?
chit happens
Old Feb 3, 2007 | 09:11 PM
  #45
Nmax92's Avatar
if so can anyone explain why the axles are not fitting flush with the seal?
Old Feb 4, 2007 | 12:17 AM
  #46
Jon94SE's Avatar
You don't need it, just chuck it
Old Feb 4, 2007 | 06:31 AM
  #47
mod or sell?
maybe they gave you the wrong axles?
sometimes you have to to get them in flush.
maybe you have the wrong seal?
Old Feb 4, 2007 | 09:47 PM
  #48
Nmax92's Avatar
The seal I got got from the nissan dealer. Maybe your right, the axles maybe wrong for the car. tomorrow I'm going to put in the new axles I bought to fit the trans. I guess I have to cross my fingers.
Old Feb 7, 2007 | 09:25 PM
  #49
Nmax92's Avatar
Ok fellas. here is the deal. I put in the new axles today, but I'm still getting a slight leak. I put in new seals also. I'll see what happens over the next few days.
Next, I'm getting a rubbing feeling from the front when I'm driving. It goes away when I depress the clutch pedal about 3/4 the way.
I'm thinking the distance of the pedal in relationship to the firewall pedal to be adjusted by the way of bringing the clutch pedal bracket farther away from the firewall. I would have adjusted it today, but its too damn cold in NYC.
Could I be right about the adjustment?. this is definitely a learning experience......never again. LOL!!
Old Feb 8, 2007 | 06:37 AM
  #50
maxitech's Avatar
Originally Posted by therealgoon9
is this it?
My kit came with one of these, too. I chucked it...Haven't had any problems...Would there be any consequences to this action?
As for the axle seals leaking, the passenger side had a bad leak at first (even after installing new seals), pulled it and replaced the seal again, this time there is still a small leak, kind of a nuisance. Take the old seals with you to the dealer when ordering replacements, this eleminates any confusion.
When mounting the clutch pedal (title of thread), I advise reinforcing the firewall. I didn't at first and used stacks of washers as spacers. About a year later my firewall cracked and I had to remove the pedal and sandwich a piece of sheet metal in between.
Old Feb 8, 2007 | 08:52 AM
  #51
Nmax92's Avatar
Maxitech - How much space do you think I need in between the pedal bracket and the firewall? I have about 1 1/4".
Old Feb 8, 2007 | 08:56 AM
  #52
Nmax92's Avatar
Update. I got the speedo working! Now is the issue of the fluid leak and the rubbing coming from the trans. I'm gonna take it to a tranny shop next week
Old Feb 8, 2007 | 07:47 PM
  #53
vansskaterfreek's Avatar
the vibrating sounds like a mis-aligned clutch....... yeah change those axles too...... that may solve your leaking issues
Old Feb 8, 2007 | 11:38 PM
  #54
Nmax92's Avatar
I changed the axles. I think the seals are not seated properly in the trans.
Old Feb 14, 2007 | 11:54 AM
  #55
Jbr8k's Avatar
Nmax92 don't forget the write-up
I'm gonna need it.
Old Feb 14, 2007 | 12:21 PM
  #56
maxitech's Avatar
Don't remember the exact measurement, but I just stacked washers and test fitted it until it was close to lining up with the brake pedal.
And instead of changing the brake pedal just take a sawzall to the current one.
Also, what are you using for a spacer?
Old Feb 15, 2007 | 05:02 PM
  #57
Nmax92's Avatar
Jbr8k - I won't. I'm working on it now.
Maxitech - I used a bunch of washers.
Old Feb 19, 2007 | 07:02 PM
  #58
CapedCadaver's Avatar
Call me Wookiee Goldberg
Alex is right. its the pilot bearing. my problem is I have no clue where it goes. It doesn't even fit in the center of the flywheel. any idea guys?
My dad had an old Chevy something in the 60s that he swapped AT for MT, and he had a bearing custom-machined by Boeing (yeah, the airplane/helicopter factory... he worked there during Vietnam) and he then froze it for a few days before putting it in. When it expanded as it thawed, he said the fit was perfect. But of course a lot changes between 60s Chevys and 90s Maximas.
Old Feb 22, 2007 | 07:34 PM
  #59
Nmax92's Avatar
update fellas - remember the trans fluid leak problem I have been getting?......I'm still having it! G-damn it! I bought new seals too.
I need a little confirmation here. when I was taking out the old seal on the trans I looked into the opening and noticed a bar that seems to be in the middle of the trans at about a 30 degree angle. Is that bar supposed to be situated like that?
i have a feeling that bar is stopping the axles from seating flush with the trans in turn causing the leak. Could I be right?
Old Feb 22, 2007 | 10:11 PM
  #60
Alex_V
Nope thats part of the diff, it rotates with it. Make sure you prelube the seals and theres no scratches in the metal.
~Alex
Old Feb 23, 2007 | 06:42 AM
  #61
mod or sell?
where are you getting the seals from?
Old Feb 23, 2007 | 01:43 PM
  #62
Brudda Bob's Avatar
NMax, I had the exact problem and resolved the issue after the 3rd attempt. 2nd and 3rd times were OEM seals.The seals are EASY to pinch so be extremely careful.I used some Indian head gasket sealer (sold in Auto Zone) on the seal and I bel. thats what did the trick .The sealer dries quickly and if i's not in fast enough, youre gonna be in problems.
Part of the problem was the seal but I think the real problem was that the axle wasn’t locking inside the tranny. It felt locked but would slip out if it was pulled hard enough. That problem was resolved by trying 3 different sizes of Nissan C clips on inner part of the axle. If the C clip doesnt have enough tension it wont open and lock the axle. If it's too big then it wont work.
I lubed the space a tiny bit to hold the C Clip in with Multimpurpose grease.
I noticed that there was a specific spot where the axle would go in with with minimal effort.I scribed a mark (kinda like an alignment thing) and was able to remove and replace the axle several times without ANY problems using this mark.I dont know if they are all like that or if it was my imagination. (I seem to recall there was also a tiny indentation on the axle which is where my mark actually was)
I spent about 9 plus hrs and removed the entire setup and redid it about 6 times without any power tools. Each time I thought it was fixed but it wasnt, so set ample time aside to complete this task. I used a crate to support the entire rotor/strut setup,attached a hook and rope to the strut thingy and tied it to the rear of my car otherwise it gets in the way of removing and replacing the axle (unless you have someone to assist). If you do this be sure to put a cloth against the rope otherwise it's gonna brace your car and damage the paint.
(N.B I was advised by my mechanic about using the grease and he gave me the OEM C clips. Another mechanic told me about using the Indian head and said he always uses it for axle seals).
Final check: Bolt everything up(minus wheel) and leave the car on the jackstands (MAKE SURE ITS SECURE). Drive it through LOW speeds/RPM using all the gears for a few minutes to ensure its not leaking AND PRAY.Check for leakages AFTER THE ENGINE IS SHUT OFF.fINALLY there is also a ton of info. archived on the site regarding that problem. Axle specs. seals different methods etc.
Old Feb 23, 2007 | 01:47 PM
  #63
maxitech's Avatar
Pics, or at least a description of the indian head seal puller, Bob?
Old Feb 23, 2007 | 02:12 PM
  #64
Brudda Bob's Avatar
http://www.permatex.com/documents/td...tive/20539.pdf
http://www.favoritehardware.com/auto...o-1419010.html
Old Feb 23, 2007 | 05:44 PM
  #65
Nmax92's Avatar
Brudda Bob - that is EXACTLY what is happening to me! The first set of seals I used were from Nissan, the second set are from autozone. do you know the exact size of the c clip?
So to recap, your saying to get a small enough C clip that would lock the axle in place and the sealer would go on the side of the seal that makes contact with the tranny. I'm sorry about that 9hr job man, I hope it wouldn't take that long for me. Thanks for the info, wish me luck
Old Feb 24, 2007 | 11:23 AM
  #66
Brudda Bob's Avatar
NMax I think you should 1st determine if it's the axle or the axle seal. If the seal is properly seated (end of the seal lines perfectly up with the edge of where it's seated i.e if you rub your fingers the seal shouldnt protude) and isnt pinched then it wouldnt leak.
Do the easiest of the two or lets assume the seal is ok.
Make sure that the axle is locking 100% the way it's supposed to.
You can determine this by gently tugging on it on it after the installation.
If it slides out with minimal force then it isnt locking.
Dont know the size of the clip because the bag was discarded (the diff. in the sizes were microscopic). They were OEM clips and it had several sizes. My axle is for the VE5 LSD/ABS so it's different from yours which I bel. is the VG. Also, if you have the CORRECT size and it doesnt have enough tension it WONT lock. I had to go thru each clip and tried them about 4 times each. They all SEEMED to work but didnt.Be sure you lubricate the GROOVE on the axle with grease.
Be careful about using the Indian head because it dries really fast.Just rub a thin layer onto the inner part of the tranny where the seal goes.
I dont know if it's possible to insert the C clip into the tranny BEFORE the axle. You can try this and then slide the axle in, the most important thing is for it to LOCK. Doesnt make much sense this way but sometimes one has to try the unconventional method.
The 1st time 3 of us tried to get the axle in for about 2 hrs without any luck (diff. time from my 9 hr. ordeal). We later discovered that the previous C clip was stuck inside the tranny and with the additional clip on the axle...well it was like fitting a square peg in a round hole.
Good luck!!!
maxima-junky
Oct 21, 2015 05:17 PM
TurboA32
Aug 27, 2015 08:44 AM
maxima-junky
Aug 13, 2015 09:59 AM
