oil question
oil question
can i use DOT 4 for my brakes? will it harm the o-rings inside the brake master cylinder? also i was thinkin' about changin' my tranny oil, what can i use to replace the regular gear oil for my tranny?
in your tranny you need to be 100% sure that you get GL4 NOT GL5, GL5 causes Syncro issues.
Napa is one of the few places that carry the correct GL4 fluid.
Originally Posted by marquisdee
I went to autozone today and they also sell GL4 gear oil. I can't remember the name of the brand but I have some in my car.
It's made by coastal,and no it is not gl4 oil....The coastal stuff is compatible with gl3/gl4/gl5 as a top off fluid only,it is not to used as the primary oil in the transmission...
you can use DOT4 if you want it's 100% compatible with our brake system.
for the GL4 oil what brand do i have to get for my tranny?
i have the 300zx front calipers and what do u mean if i want its 100% compatablility with our brake system?
It's only DOT5 that has an issue as it is silicone
That being said there is a DOT5.1 that can be used without a problem.
Brake fluid explained.
http://auto.howstuffworks.com/question451.htm
Mar 12, 2020 12:06 AM
kjlouis
Oct 3, 2015 05:29 AM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
