my window sucks in the winter
Old Feb 18, 2007 | 04:03 PM
ozzombie13's Avatar
I will eat your children
ok first problem i was just out to dinner and come out to find the passenger front window to be down. at first my girlfriend thought it was missing but there was no broken glass. reall quick i got the door pannel off and checked to make sure the glass was ok. it is but i think the regulator broke or atleast the little plastic part that lifts broke. im not sure but its cold and dark so im not messing with it right now so its taped up in place. reglators are a common proble, but how bad are they to replace? and we cant get them new anymore can we?
and the second problem not as bad is the driver front when rolled down about 3 inches makes a really loud screech sound. not sure whats causing that but i havent had that door pannel off in a while.
Old Feb 18, 2007 | 04:15 PM
Hectic's Avatar
you can get new regulators everywhere. replace and enjoy.
Old Feb 18, 2007 | 05:05 PM
JakeDilingo's Avatar
Ive replaced 5 regulators, 3 in my friends maxima. got all from junkyard. Pretty easy to replace. carefull if your windows are tinted
My windows seem to roll up and down slow, some worse than the others. my driver window rolls really slow when its almost all up or all down...any suggestions for that?
Old Feb 18, 2007 | 05:12 PM
internetautomar's Avatar
mod or sell?
regulators are an easy swap job.
I'd probably do most of it with the door closed if you lack a garage.
Currently I'm getting $40 for new regulators, but I'm working on getting a less expensive batch in the future.
oh, and for Jake, if they window is slow chances are the regulator needs lube badly.
Old Feb 18, 2007 | 05:17 PM
marquisdee's Avatar
I went to the junkyard today to get a window regulator. I was too lazy to take the door panel and everything off. So I bought the entire door for $40 . I'll just swap everything over next weekend.
Old Feb 18, 2007 | 07:13 PM
what kind of lube you reccomend?
Old Feb 18, 2007 | 07:38 PM
mod or sell?
I don't. I haven't seen anyone successfully extend the life signifiantly by lubing.
Old Feb 18, 2007 | 08:52 PM
Cliff Clavin's Avatar
Way out West
The best thing to do if your regulator is slow is buy a new motor. I bought a new regulator with a new motor for my driver door one and I am totally glad I did. It gets 10x more use than all of the others.
When I replaced the rear one, I bought a regulator without a motor and just swapped the old one over.
I would also recommend against buying regulators from a junkyard. These parts are prone to go out on these cars, so you might have just a 50-50 chance of it lasting very long. If you buy a new one, you know it's probably going to last you a while. They aren't that expensive to replace.
Now, if I could only figure out how to get the door panel off with the door closed, I would be golden.
Old Feb 18, 2007 | 09:29 PM
ozzombie13's Avatar
well the door panel is already off. i have done 2 regulators on my dads crown vic, but they had rivets that held them in. is it all bolts in the max?
Old Feb 18, 2007 | 09:41 PM
Hectic's Avatar
sell him your FR regulator
Old Feb 18, 2007 | 11:27 PM
bvtran's Avatar
94c Big Max
not sure why you guys would want to get junkyard stuffs. A whole new regulator + motor costs only $25 on ebay plus SH. I strongly recommend you get new motor since your living in cold climate. The greases in your old motor was probably went bad and it will freeze up. Don't try to re-grease it either. I'd tried doing that and it was impossible to open up the motor without damaging its internal organs.
http://search.stores.ebay.com/Car-Pa...020616QQsofpZ0
Old Feb 19, 2007 | 03:14 PM
thats cheap, didnt realize even to look on ebay for those, guess I'll be replacing a few this spring
Old Feb 19, 2007 | 04:41 PM
marquisdee's Avatar
The only reason I got one from the junkyard is because I needed another door. It was cheaper for me to get a door than to have the dent in it replaced. I think I'm going to order a new regulator and motor since I have to take the door apart anyway.
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
