Power Window Problem
Old Mar 4, 2007 | 12:27 PM
ninjasword71's Avatar
Is there a detailed thread on how to remove the REAR door panel and find out why the power window doesn't work anymore? I can hear the motor going but seems to have too little power to move it. I need to know how to trouble shoot this too if possible.
Old Mar 4, 2007 | 03:07 PM
elusivemax93's Avatar
my easy solution bro is disconnect the connector to the motor in the door take a 9v battery (like an R/C car battery) and see by changing the way u put the wires from the battery to the connector going to the motor if the motor is running right or not and from the sounds of it your having mechanical failure from the motor as its struggling to work at its normal voltage to roll up and down. u can also take a DVOM (Digatl Ohm Volt Meter) and check its ohms of resistance coming from the connector thats going to the motor and see if its really high which would state thjat its having to draw more voltage to try to roll up your window. or maybe it is that the wire on the trace has jumped its trace and not letting it roll up nor down not sure as u only gave me so much information to think from.
Old Mar 4, 2007 | 03:09 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like the regulator is broken...
Old Mar 4, 2007 | 04:57 PM
internetautomar's Avatar
mod or sell?
no detailed write up on the rears that I can think of.
BUT on CraigB's Geocities site there is a writeup on doing the front which is virtually identical to the rears.
Old Mar 4, 2007 | 11:09 PM
Maxima9750's Avatar
My driver's side front window is doing the same thing. I am convinced that the regulator is going since that is the only one on my car that hasn't been replaced. I replaced my passenger side rear window regulator about 4 months ago and I followed the guide on Craig Brace's site. It is easy to do and straight forward. It should only take 45 minutes to an hour if this is your first time.
Old Mar 5, 2007 | 06:45 AM
slickblack94's Avatar
bartender....another round of regulators here plz......
Old Mar 5, 2007 | 06:48 AM
Pearl93VE's Avatar
I can has?
Haha, I know right. When I got my VE ALL the windows were working; pretty scary actually. I think it's the first time I've ever been in a maxima with all working windows.
Old Mar 5, 2007 | 03:00 PM
heresmymind
yeah the fronts and rears are the same. I had to help another .org member do his. it took me 15 mins tops. 1 ratchet w/ 1 socket. and 1 magnetic phillips head screw driver. there are 2 bolts holding the upper and lower bar. 3 holdering the motor. and 1 holding the window bracket to the bar.
Old Mar 5, 2007 | 10:12 PM
RyderMax's Avatar
OK - sidebar coming up
Where's a place you can get a rear regulator for cheap in Canada. I just hate getting stuff from the US thru ebay because of brokerage, UPS, exchange, paypal and the rest of that junk
m
Old Mar 7, 2007 | 11:53 AM
my maxima has all working windows as far as now still none of them have broken or gone wrong on me very nice to have these types of cars that you dont have to replace window parts to have them working
Old Mar 7, 2007 | 03:42 PM
92Maxin's Avatar
Man i just finsihed installing a new motor and regualtor in the front driver side. What sucked is after doing all that by my self i find out its the switch thats not working!!
Old Mar 7, 2007 | 10:40 PM
VEvolution's Avatar
I miss my VE
When I got my 92'SE, both rear regs were done for and the passenger followed shortly after that upcoming winter.
Old Mar 8, 2007 | 08:29 PM
I do hear the motor working but no or very little window movement. It needs help to close.
Old Mar 8, 2007 | 08:48 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like a bad regulator...
Old Mar 12, 2007 | 08:45 AM
SolSagan's Avatar
When I bought my car the old own rigged the back left regulator to hold the window open with a tub clamp and a twisted arm. I had to change it out.
Recently my front passenger is going out. I say just change em all they go out at about the same time.
Each is a 15 minute job. All you need is someone/thing to hold the window closed. Take the door panel off have someone hold your window up. Unscrew the assembly from the window and the door. unscrew the motor. Then just reverse the process with the new stuff.... nuff said.
Old Mar 12, 2007 | 04:49 PM
92Maxin's Avatar
Just to add to this. If you dont have anyone to help you then use duck tape to hold the window up. Just stick it to one side then up over the jamb and stick it to the other. to keep from getting adhesive on your door just place a rag or something over the frame so that the tape only touches the glass.
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
The Frye
Feb 3, 2019 08:34 AM
trungg86
Sep 4, 2015 04:58 AM
