Slight lean-age
Old Mar 7, 2007 | 03:19 PM
Jon94SE's Avatar
Slight lean-age
My cars leaning towards the front passenger side, It seemed to start doing it after I replaced the wheel bearing up there. I know that has nothing to do with it but I'm wondering what would cause it to do that. We've got some pretty nasty potholes going on around here right now, which I try to avoid but sometimes at night I dont see them untill it's too late. Even if the strut was wearing out, shouldn't the spring keep it up where it's supposed to be? Right now I can fit one finger between the tire and the fender on the driver side but I can't fit one between on the passenger side. I know I probably had the sway bar too tight when I put it back together but I backed it off a bit and it's still doing it. Is there a common cause for this? Thanks.
Old Mar 7, 2007 | 03:21 PM
Greeny's Avatar
¯\(°_o)/¯
Blown strut maybe?
Old Mar 7, 2007 | 03:23 PM
Jon94SE's Avatar
Shouldn't the spring keep it up where it's supposed to be though?
Old Mar 7, 2007 | 03:28 PM
Greeny's Avatar
¯\(°_o)/¯
Dunno?
Have you been haulin alot fat girls around lately?
Old Mar 7, 2007 | 04:10 PM
Burn MF Burn's Avatar
busted strut. Not too much of a job if you have the tools.
Old Mar 7, 2007 | 06:23 PM
Chris Gregg's Avatar
Get Off My Lawn
Simple, just jack it up and inspect the spring and the hub. Something has happened; did you retighten the lower ball joint? And yes, despite the spring your car could be sagging as a blown strut would allow the car to squat a bit lower than normal.
I wish I could find the images. I actually had an Eibach spring blow out on me. I was hauling full passenger load and heavy system in trunk...rear driver's side spring. Eibach said they'd never had this on a Max at the time. It clearly dropped the car in that corner, raising the front passenger's corner.
Old Mar 7, 2007 | 10:14 PM
xx-Marshall-xx's Avatar
kthxbye2u
hmmm my car does the SAME exact thing, i had new tires and FULL allignment and it still pulls...
guess i know what it is now...
Old Mar 7, 2007 | 10:51 PM
Jon94SE's Avatar
Yeah sounds like the strut then. I feel dumb I meant to mention before that when I had it apart I pushed up on it a bit and it was a little "squishy" but not too much. I just thought it was strange that it didn't start untill after the bearing replacement. They're tokico blues. They were in really good shape when I bought the car, but it seems that Tacoma's roads have gotten the best of them. And no..no fat chicks
Old Mar 8, 2007 | 12:50 AM
elusivemax93's Avatar
dude tacoma and all surrounding areas have alot of bad streets and u living in tacoma have to deal with the big hills alot lolz. i live in spanaway like 30 minutes south of tacoma and there are alot fo bad streets here. lolz
Old Mar 8, 2007 | 01:13 AM
rmdl51's Avatar
White_Shadow
I'm in the same boat!!! I have no idea why but the front is moving to the passenger side, it's even pushing my side corner light out of it's place, I believe this is even affecting the aiming of my headlights (which is terrible) and I adjust some time ago but then again it's happening, I can easily stick a finger at the driver side from the top of the hood but the passenger side is so narrow, could it be the vibration of a bad engine mount?
Old Mar 8, 2007 | 02:49 AM
maximagician's Avatar
are the tires the same size??
Old Mar 8, 2007 | 06:08 AM
Jon94SE's Avatar
Wow, that sounds pretty bad. I think you've got it a little worse than I do. I just get some slight tire rubbage on bumps or when there's people in the car.
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
05RLS2
Sep 27, 2015 09:24 PM
msellas
Sep 23, 2015 09:16 PM
RWCreative
Sep 21, 2015 11:01 AM
