Does anybody have an old VTC spring laying around?
Old Mar 8, 2007 | 08:14 PM
  #41
Josh's Avatar
Originally Posted by Aaron92SE
In your pictures, it looks like they are a thicker spring.
It's such a huge difference compared to what I got. There MUST be a VTC rebuild kit that superceded another! I certainly got the older kit.
Do you have a Cali spec 1992 Maxima?
Well I'm not sure, it was bought originaly in Texas, but I think I have run into error codes that are cali-spec only(can't remember off hand what they were). But considering the car spent most of its life in California and was always dealer serviced I don't know what was done to it. Actually I have all the records of everything done to it in a 2" thick folder but thats alot to wade through
EDIT: I think my vin says it isn't cali though, but i don't remember what the code was for that.
Old Mar 8, 2007 | 08:16 PM
  #42
Aaron92SE's Avatar
NWP Engineering.com
I know it's a Cali spec b/c if you have an EGR temp sensor on the 1992 SE, then it's Cali.
That makes me wonder. When you ordered your VTC rebuild kit, did you give them your VIN or did you tell them you were Cali spec? What information did you provide them when ordering the kit? Where did you get it from?
Old Mar 8, 2007 | 08:21 PM
  #43
Josh's Avatar
When I ordered the kit I just gave them the part number(13072-97E00). I ordered it through my local dealer and the parts manager had never heard of this before. And that was the other thing I recognized I do have a egr temp sensor, so it is cali spec I guess but I think my vin says otherwise.
  #44
Aaron92SE's Avatar
NWP Engineering.com
If you look on the stamped metal plate on your firewall. Your model number should say: ELJ30GAEV
If it ends in "V", then it's Cali spec. If it ends in "U", then it's non-Cali spec.
Old Mar 8, 2007 | 08:23 PM
  #45
Aaron92SE's Avatar
NWP Engineering.com
Ok. So they gave you the correct part number and didn't do any fancy lookup according to your VIN. Thanks.
Old Mar 8, 2007 | 08:30 PM
  #46
Josh's Avatar
Yep V hmm I don't know what I was reading before.
Old Mar 8, 2007 | 10:31 PM
  #47
xx-Marshall-xx's Avatar
kthxbye2u
when did you do these? about a year or two ago? (from your mileage)
you told them that p/n?
and you got the part...that easy
thanks for the p/n if so
Old Mar 9, 2007 | 09:48 AM
  #48
lanedrifters's Avatar
Just measured a set I have. Old ones. 2.625 and 2.623. Both kit #s were 13072-97E00
Old Mar 9, 2007 | 10:22 AM
  #49
Aaron92SE's Avatar
NWP Engineering.com
So those are new VTC springs?
If so, then it doesn't sound like the taller ones Josh got. The taller ones should measure over 2.80".
Old Mar 9, 2007 | 12:18 PM
  #50
Nope, old ones I saved, for no apparent reason.
Old Mar 9, 2007 | 12:33 PM
  #51
Aaron92SE's Avatar
NWP Engineering.com
Cool deal. Thank you!
Old Mar 9, 2007 | 02:41 PM
  #52
Pervis Anathema's Avatar
Originally Posted by Michael
His car still isnt ticking (well last I saw it anyway) after 2 years so I dont think its the spring that is the problem but maybe something you did or the oil galleys are restricted.
Still doing fine but I haven't put a lot of miles on it. 200,5~ right now. It does hit redline almost every single time I drive so about the actual wear. I am using the V8 'yota filter and Castrol GTX.
Old Mar 9, 2007 | 08:26 PM
  #53
Phoenix's Avatar
Lives in a Maxima
Originally Posted by MrGone
I'm curious if Nissan improved the spring in the rebuild kits or if it's the same as new and essentially a consumable. It would be nice if they did improve the spring to make it more resistant to fatigue.
(If the springs are improved, which I don't believe they are, maybe you somehow got new old stock, but in that case they couldn't be the rebuild kits. Besides factory springs lasted longer than 1000miles. My money is on either your assemblies are worn out (lowering the spring rate) or you got used springs (maybe an employee switched them, maybe someone returned them and the parts guys were none the wiser, etc).
Something tells me that if they don't even make our oil filters any more, they're not going to bother making better springs for our VTCs. Nissan doesn't care about us anymore.
Old Mar 10, 2007 | 06:36 AM
  #54
Josh's Avatar
You think Nissan makes those springs?
Old Mar 10, 2007 | 06:38 AM
  #55
Josh's Avatar
Actually I did them exactly a year ago this week, yep just told them the p/n and that was it.
Old May 30, 2007 | 07:36 PM
  #56
James92SE's Avatar
2 VE's are better than one!
Bump
I found this on a generic auto forum:
At the time of this posting, I have my 94 Maxima SE's engine
disassembled because of what everyone told me, was the VTC problem.
This car was manufactured in February 1994.
When I was lining up the marks in the timing chain before removing the
VTC, I noticed that the camshaft chain tensioner was not keeping tension
and as the camshafts rotated, the valve springs would force the
camshafts to spin and take the chain slack, and when they did so, the
chain would generate the dreaded "VTC noise". These tensioners are
hydraulically operated and this would explain why it takes some time for
the noise to disappear after starting the engine. Part Nos. for the
tensioners are 13070-97E10 for the Right Hand side (closer to the
firewall), 13070-97E16 for the left hand (closer to the front of the
vehicle).
I am now waiting for the camshaft chain tensioners to arrive from
1stnissanparts.com.
Do you guys think this explains the inconsistencies regarding the symptoms people describe and/or why sometimes grounding the VTC's doesnt work?
Aaron, did you do yours yet?
I'm about to order rebuild kit(s), but I sure wish there was a way I could make sure to get the longer/stiffer springs. Heck, I think if I could buy whole new assemblies (are there even any around) I would
Old May 30, 2007 | 07:42 PM
  #57
mikekantor's Avatar
I think the clacking of a loose chain would be far different than VTC clacking.
By the way I just did the rear VTC on Monday so I can still measure the old spring if needed, although I dont have any tools to measure it to as high a precision as Josh. Let me know...
Oh, and my front VTC was louder and made noise more often than the rear, the old spring in it was far shorter than the old spring in the rear.
Old May 30, 2007 | 08:21 PM
  #58
Aaron92SE's Avatar
NWP Engineering.com
No I haven't ordered mine yet. When you order these springs, tell the dealership to take an accurate measurement to confirm that you get the longer springs.
That's what I'm going to do. I will not try the shorter spring again after the VTC tick came back in less than 1K miles! You have no idea how bummed out I was after doing all this work for nothing.
Old May 30, 2007 | 08:29 PM
  #59
mikekantor's Avatar
1K?! how in the world can it fail that fast, clogged oil lines? Try a higher viscosity oil.
Old May 30, 2007 | 08:34 PM
  #60
Aaron92SE's Avatar
NWP Engineering.com
I don't know. Nobody seems to know. I either got a worn out VTC rebuild kit (which I kinda doubt) or I must have some severely clogged gallies.
But 1K miles is the fastest anybody has ever heard of. I am VERY sure I did the actual rebuild correctly. But I didn't clean the oil gallies or replace tensioners or guides. I have been using 5w30 Mobile 1 sythetic for a while now. Back when I did the rebuild, I was using 10w30 Castrol GTX.
I will do the VTC rebuild once again. But I will make sure the springs are the longer ones plus I'll clean the oil gallies.
Old May 30, 2007 | 08:40 PM
  #61
mikekantor's Avatar
Thats funny, I ran Castrol GTX 20w50 for a while and just now switched to the Mobil 1 5w30 synthetic since both VTCs have been rebuilt and I want to treat the engine better. So if my VTCs fail now I'll now that this oil is to blame, and will switch back.
My front is a five weeks old now, 2200 miles, mostly highway.
Old May 30, 2007 | 08:44 PM
  #62
Michael's Avatar
Back in a 3rd Gen.
20w50 is way too thick for the VE...I would not recommend running it.
Old May 30, 2007 | 09:10 PM
  #63
Aaron92SE's Avatar
NWP Engineering.com
Yeah, I would stick with what Nissan recommends.... 5w30 in colder climates and 10w30 in normal/warm climates.
I am in NC. I don't need 5w30 for daily driving. In fact, 10w30 would be best. But I only put in 5w30 just to squeeze out that extra hundredth of a HP since I launch my car at a cool temperature.
20w30 is definitely too thick when the motor is cold. Once it's warmed up, then it's the same.
Old May 30, 2007 | 10:02 PM
  #64
mikekantor's Avatar
Yeah, it was bad advice from someone to whom I no longer listen to about cars... back then I didnt know squat
Old Jun 27, 2007 | 07:16 AM
  #65
Aaron92SE's Avatar
NWP Engineering.com
Sorry for bumping an older thread. But I'd like to add some new information for those that like to search.
Anyway, I recently bought new VTC springs. I was able to get them measured before ordering and these are definitely taller than the measurements Josh and lanedrifters gave me.
The new springs I bought both measure exactly 2.761" in height.
Josh's old springs measured 2.585" and 2.611". Lanedrifter's old springs measured 2.625" and 2.623". My new springs are over an 1/8" taller.
I might do the rebuild along with the tensioners that I bought within the next few months. I'll be sure to bump the thread again once I rebuild them and have results to share.
Old Jun 27, 2007 | 11:19 AM
  #66
Bret89SER's Avatar
looking forward to the update...
I also need to get a spacer from you! It is great to be back in the seat of a 3rd gen - I bought Michael's 93 - awesome car.
Old Jun 27, 2007 | 12:02 PM
  #67
Jeff583's Avatar
But yet the part numbers are the same for all of the different height springs. I hope i can get the longer ones at my local stealership.
Old Jun 27, 2007 | 02:15 PM
  #68
Aaron92SE's Avatar
NWP Engineering.com
Exactly. The part number is still the same. Kaleb (the Courtesy 3rd gen OEM parts king) doesn't even know why some springs measure differently than others.
Your dealership probably won't have this kit in stock. Just make sure you have the part number when you contact them b/c it's not a part that they can look up in the parts department. It's a service part.
If they are nice, ask them to measure the new spring before you pay. Just make sure it's longer than 66 or 67mm. The new ones should be just over 70mm.
Old Jun 27, 2007 | 02:31 PM
  #69
James92SE's Avatar
Where did you order your taller springs? I better order some
Old Jun 27, 2007 | 03:14 PM
  #70
Aaron92SE's Avatar
NWP Engineering.com
Kaleb at Courtesy.
Old Jun 27, 2007 | 04:20 PM
  #71
James92SE's Avatar
I thought he wasnt working in parts anymore?
Old Jun 28, 2007 | 09:33 AM
  #72
Aaron92SE's Avatar
NWP Engineering.com
He's not. But, I was still able to talk to him a little bit. There are a couple good guys in parts (Brian and Joey) that will be able to look up the part for you if you have the part number.
For those that are wondering how to get a hold of Courtesy Nissan Parts Department:
1-800-527-1909
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Redfox
Sep 28, 2015 10:41 AM
