fuel leak from tank/filler/something
Old May 16, 2007 | 07:49 PM
  #41
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by JRS89MAX
Im thinking even though its a fuel vent line it was losing some pressure. Cause I had a nice slice on the hose. Now that its sealed with a new hose It must have built some pressure it didnt have before that may change my idle. Correct me anybody if im wrong.
The vent hose is only pressurized by the pressure built up in the tank. It will not effect the actual fuel that the fuel pump is pushing to the motor.
So, I think your high idle is something different. The changing weather and running the AC has an effect on the idle. If you are idling steady at 1200rpm constantly and it never drops below that, then something has changed. If it's not idling smoothly, then look into normal tune up items. If everything is good (plugs, wires, cap, rotor, fuel filter, air filter, etc) then you can adjust the idle to compensate. If idle still fluctuates, then look into cleaning your IACV or get a new one.
You can follow the idle adjustment procedure after you have already gone through the diagnostic checklist in the Factory Service Manual.
Old May 16, 2007 | 07:51 PM
  #42
CapedCadaver's Avatar
Call me Wookiee Goldberg
Originally Posted by Maxima Man
Well my idle is high when I start my car cold like 1500 rpms then 3 min later it will idle at 900-1000 rpms then once I drive it it will idle at 800 rpms.
I have my idle set at 850 rpms when hot so when I put it in drive my idle dosent go low enough to shake my car. If i set the idle at 700 then put it into gear it would drop to 550 then shake my car. (Anyone else have this prob?)
I dont think your high idle has anything to do with your fuel vent line.
But could be i guess?
check your iacv. my brother's car's IACV (a 93 camry) reacts SO FAST that the P-D shift notices a near instantaneous RPM correction, and a blip-drop of maybe 50RPM if that. The idle on that car is impeccable, and no matter what accessory you engage, it reacts with laser precision. My car, a 3gen maxima... doesn't. If i shift into a gear it dips and bobs and gasps and jumps until it FINALLY decides on an RPM to lock into... sortof... except it still is jumpy and blippy in or out of gear. My iacv is bad i think, because the reaction is pathetic. That and turning my ECU screw makes my idle change. It's not supposed to affect a warm idle, and my neutral warm idle is like 950 with the iacv enabled.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
