Need new Clutch Master Cylinder? Or just rebuild?
Old Mar 10, 2007 | 12:15 PM
hoyshnin's Avatar
Baby's on the Half Tip!
I had a problem with leaking clutch fluid and thought it was the slave cylinder, after closer inspection though, the clutch fluid is actually leaking inside the car down the clutch pedal, so it's the clutch master cylinder after all. My question is that as I push in the clutch, I noticed that the leak is where the piston attached to the clutch pedal moves in and out of the master cylinder. Do I need to replace the whole clutch master cylinder, or should I consider a rebuild kit that maybe includes some sort of seal?
Autozone offers master cylinders from $28 to $42 and rebuild kits from $10 to $19. So there isn't a huge difference in price, but what do think? Other than the leak, there is no problem with the clutch.
Also, how should I go about bleeding it after installation or rebuild (I have a hand pump speed bleeder type thing I used for bleeding my brakes).
Thanks!
Old Mar 10, 2007 | 03:28 PM
Greeny's Avatar
¯\(°_o)/¯
If you plan on keeping your car for a long time,and don't want to have problems 3 months from now,go to the dealer for the m/s...Yes you will pay more,but you will have a part that will last for many years without problems...
If you want have problems,then go grab the autozone garbage..
Or you could buy my used oem master cylinder...
Old Mar 10, 2007 | 04:19 PM
maxitech's Avatar
I bought one from internetautomar last year for $35 and have had no problems...not sure how much the dealer wants, but it will definitely be more.
Old Mar 10, 2007 | 04:30 PM
goon9's Avatar
i had luck with a napa slave.
Old Mar 10, 2007 | 04:34 PM
Matt93SE's Avatar
STFU n00b!
rebuilt mine 7 years ago. no porblems yet.
If I were going to do it again, I'd just buy a reman part and install it. saves an hour of labor to rebuild..
Old Mar 12, 2007 | 07:43 AM
hoyshnin's Avatar
Where did you get the rebuild kit? And did you replace the piston too when you rebuilt it? (I saw that some kits include a piston and some don't).
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
Pied
Sep 26, 2015 03:29 PM
