it just doesnt end..
Old Mar 11, 2007 | 10:42 AM
speedfreak4996's Avatar
Alright ive havent been on in a while, but this ve is driving me up a wall..
I got a 93 ve5 and i take it out every night to get some miles on it and to keep it going. Ill start it .. drive about 20 miles with it.. and its got plenty of pep. Ill come to a stop light or even sometimes sustain 65 on the highway for a while and itll just turn into a gutless brick. Just as if someone flicked a switch and said nope no more power.
Ive changed alot of the tune up items, coil packs are all tapped up, new MAF.. what could it possibly be? Its gettin no better than 11-15 mpg. I dont want to get ride of the thing, but i just cant deal with this thing.. prob after prob..
Old Mar 11, 2007 | 11:48 AM
ghostmax's Avatar
oxygen sensor
knock sensor
Does it idle okay?
Old Mar 11, 2007 | 02:45 PM
Yeah man its idling pretty smoothly , sometimes it pops a little out of the muffler at idle.. idle fluctuates from time to time as well
im thinkin the knock sensor.. but id like to really know its that before i dump all sorts of cash into it
Old Mar 11, 2007 | 02:49 PM
Josh's Avatar
Sounds like a knock sensor, pull out a multimeter and see what its reading is.
Old Mar 11, 2007 | 04:03 PM
thanks for the replies.. got my hands into it today and it looks like the previous owners grounded my VTC's.. so i ungrounded them and they dont make anynoise. Could this have been a cause to the prob?
I noticed a pretty steep lose in the low end which is also leading me to believe its a knock sensor.
i just never thought that grounded the vtc would make the ve run like such poop?
Old Mar 11, 2007 | 04:28 PM
Greeny's Avatar
¯\(°_o)/¯
Grounding the vtc's will not make it lose low end power,it will lose some top end ponies though,not much though...
if you want to diagnose the k/s without removal/replacement,try bypassing the ks with a 470k resistor for a few days..
Old Mar 11, 2007 | 04:39 PM
where is the harness for this beast.. everyone talks about the resistor trick but ive heard its risky with detonation.
got a pic of where to put that bad boy?
Old Mar 11, 2007 | 04:53 PM
Jon94SE's Avatar
I just put my VTC's on a switch recently, if they're making too much noise for my liking and I'm not planning on running it hard I'll just flip them off or on. and I did the same with the resistors. Just find the pins on the ECU and put the switches there to save your self time and hassle but be carefull when messing around down there. And good God that flash makes the engine look dirty
Old Mar 11, 2007 | 04:57 PM
Greeny's Avatar
¯\(°_o)/¯
This is where the plug is located off the main harness,keep in mind this will be plugged in to another harness on your car,with the other end going under the intake plenum....you need to put the resistor in the plug that goes to the main harness,not the plug going under the intake...
I have had my k/s bypassed for about 105,000 miles now,i use PREMIUM FUEL ONLY!!!If you do this bypass long term,you must use absolutely nothing but premium fuel...
Old Mar 11, 2007 | 04:58 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by Jon94SE
Why are you running 2 resistors???
This bypass only calls for 1 resistor...
Old Mar 11, 2007 | 05:27 PM
Jon94SE's Avatar
hmmm, good question, my friend that told me about it went with me to buy them and said to get those and put two in there...it seems to work fine though.
Old Mar 11, 2007 | 05:31 PM
Greeny's Avatar
¯\(°_o)/¯
Too "fool" the ecu the correct resistance is 470k,by putting 2 in there you increased the resistnce to 940k..
Old Mar 11, 2007 | 05:58 PM
internetautomar's Avatar
mod or sell?
I thought doubling resistors lowers the resistance
eh, I'm to sick to think straight
Old Mar 11, 2007 | 06:01 PM
Greeny's Avatar
¯\(°_o)/¯
Dunno?
I thought is was like a double scoop of ice cream..
Old Mar 11, 2007 | 06:03 PM
Gunther's Avatar
It depends on how they're wired I believe
I think parallel would halve it and series would double it
Old Mar 11, 2007 | 06:24 PM
mod or sell?
sounds right to me
Old Mar 11, 2007 | 06:40 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
sounds right to me
I've got a Computer Engineering major for a friend... he could anwer all your questions. But he's not online. arg.
Old Mar 11, 2007 | 07:24 PM
ghostmax's Avatar
In series, resistances add. So Total R= r1 + r2 + .....
In parallel, resistance as follows: 1/Total R = 1/r1 + 1/r2 + .......
Old Mar 11, 2007 | 08:17 PM
Jon94SE's Avatar
Yeah I asked my friend why two and he said if they're in parallel it cuts it in half.
Old Mar 11, 2007 | 08:24 PM
Greeny's Avatar
¯\(°_o)/¯
Well,i would like to clear this up...Is 1 470k resistor correct or do we need 2???
How did your friend come to this conclusion?
Old Mar 11, 2007 | 08:55 PM
Aaron92SE's Avatar
NWP Engineering.com
You need only one 470K resistor for the KS bypass on the VE.
If you connect two resistors in series, then it's doubled resistance. If it's in parallel like in that picture above, then it will be half resistance exactly. So hopefully, he stuck two 1M resistors in there and not two 470K resistors.
Old Mar 11, 2007 | 10:29 PM
Jon94SE's Avatar
I believe it was two 1m's.
Old Mar 11, 2007 | 10:35 PM
Aaron92SE's Avatar
NWP Engineering.com
Then you should be fine.
Old Mar 11, 2007 | 10:38 PM
Jon94SE's Avatar
Yeah, It's been working the way it should. What would happen if you had double the resistance in there? How would the computer react to that, that would cause problems?
Old Mar 11, 2007 | 10:45 PM
505max94se's Avatar
I put two 1m ohm resistors (parallel) in Jon's Maxima. I bought them from Radio Shack and this was the only option that I had to get to 500k ohms. It works just fine...
Old Mar 11, 2007 | 10:57 PM
Aaron92SE's Avatar
NWP Engineering.com
Yeah, it will work just fine. Or you could use a 470K resistor if they had that in stock.
Old Mar 11, 2007 | 11:26 PM
505max94se's Avatar
Yeah, they didn't have any in stock at that particular time.
Old Mar 12, 2007 | 05:12 AM
Greeny's Avatar
¯\(°_o)/¯
All cleared up...Thanks Aaron/505...
Old Mar 12, 2007 | 06:55 AM
Aaron92SE's Avatar
NWP Engineering.com
Oh, but to get back on topic, it sounds like you are running rich! Which will be a bad o2 sensor in many occasions. If you have never replaced that before, then definitely do that. That's something that needed to be done anyway.
After you know it's not the o2 sensor, then you can try the KS bypass just to test it. If the problem doesn't go away, plug the KS back in and try something else.
Do a tune up... plugs, check timing, fuel filter, air filter, etc.
Also, if none of those things fix it, then you need to look further into the o2 sensor. Get a FSM and do some testing. I bet you are running insanely rich, which can cause a pop to come from your muffler. It's possible you have a bad signal wire or a bad connection somewhere in the o2 sensor circuit. That would put you in the safety fuel map, which is insanely rich. I've been there! Just an idea. Good luck!
Old Mar 12, 2007 | 08:00 AM
guys thanks for all the great information. Im gonna try the 470k deal and see where that lands me. I was planning on doing a ypipe soon so a o2 sensor would be put in then.
Im still leary about using the resistor trick. I always use 91 octance fuel but i fear detonation lol.
the car has been tuned up very recently. I actually pulled the front 3 plugs and found that they smelt burnt. Not wet in gas..
something is screwy..
again thanks for the input
Old Mar 12, 2007 | 08:20 AM
Aaron92SE's Avatar
NWP Engineering.com
Well, like I said. Do a tuneup before trying to diagnose ANYTHING. Do it before you try any resistors. Check ignition timing too since I bet it's never been checked.
If you've never replaced your o2 sensor, then that should DEFINITELY be included in your tuneup!
If those things don't work, then you can check the KS. As for the KS, I would check your timing before bypassing it! Then, carefully listen for detonation when you are driving. If you dont know what detonation sounds like, you need to know BEFORE doing the KS bypass! You will blow your motor if detonation is ignored. It's possible to detonate and blow your motor all within 2 seconds if it's bad enough. So be careful.
Old Mar 12, 2007 | 09:51 AM
thanks, another stupid question...
how does one check the timing on the ve.. its got chains and all.. i thought it was a system that didnt have to be touched?
what about the indication that there is no gas on the plugs.. could that indicate a lack of spark? I had a serious hesitation before i ungrounded my VTC's.. now its great.. just low power on the low end and that heat sluggishness
Old Mar 12, 2007 | 09:56 AM
mod or sell?
you still check it with a timing light.
Old Mar 12, 2007 | 01:01 PM
Black92GXE's Avatar
Boomer Sooner
glad i have a VG.....
Keem
Dec 2, 2012 08:28 AM
Semo
32
Apr 25, 2012 09:57 AM
YungmaxiOwna21
May 4, 2009 11:00 PM
gtr_rider
Apr 23, 2008 01:38 PM
