From KYB to Koni
Old Mar 28, 2007 | 03:50 PM
'90_Maxima's Avatar
From KYB to Koni
I am switching a Maxima from KYB to Konis. Do I need to go to a junkyard and locate two OEM front stuts and pull it from a junker, or will the strut stuff the KYBs are already connected to suffice for the KYB-->Koni exhange?
Old Mar 28, 2007 | 10:27 PM
maxitech's Avatar
As long as you have a strut assembly to insert the strut cartridge into, you'll be fine...
Old Mar 29, 2007 | 12:09 PM
'90_Maxima's Avatar
Thank you for the information. I'm guessing I've got the necessary equipment still bolted on the car then. Thank you again.
Old Mar 29, 2007 | 12:12 PM
maxitech's Avatar
That's what we're here for!
Old Mar 29, 2007 | 12:32 PM
Jeff92se's Avatar
I'm needing a caw
I'm not too sure about cutting open a gas charged strut like the KYB. The rears are inserts even for the KYBs so that's no problem. It's the fronts that present a problem.
Old Mar 29, 2007 | 12:39 PM
maxitech's Avatar
Hmm...good point, Jeff...See if you can get some front struts from a local junkyard. Or, if you want to be daring, it MAY be possible to drill a small hole near the top of the strut to discharge the gas and then go to work cutting it...
internetautomar's Avatar
mod or sell?
Drill first maybe
Edit, Maxi beat me to it
Old Mar 30, 2007 | 12:17 AM
'90_Maxima's Avatar
Done. Junkyard cat I'll be.
Moochas.
AcuraLegend
Oct 17, 2016 08:47 PM
maxima-junky
Oct 7, 2015 06:13 PM
AcuraLegend
Sep 22, 2015 04:22 PM
dvcamp
Sep 18, 2015 10:17 AM
