e36 head light 2dr or 4dr
which ones fit the max the 2door or 4 door i found some e36 black housing projectors one piece side blinker can they be made to fit the the car (1992 nissan maxima se)
they 2dr and 4dr versions should be the same
you could make the blinker piece fit, but it would take a lot of body work to fill up the gaps since that light is a lot smaller. Also,the curve wouldn't really match the fenders.
Originally Posted by maximusve92
It not worth it,I want the car to be neutral and that would offset the car thanks for the info.
of course not ,I knew the one piece was out of the question I just want to know the if the 2door or 4door e36 would both fit or should I stay away from buying one or the other.
im pretty sure both are the same. then again all you are going to use are just the headlight housings and not the BMW brackets. i think the 2dr and 4dr headlight brackets might be different but the housings should be the same. remember you will use your stock maxima headlight brackes and not the BMW headlight brackets for the conversion.
I also wanna do this sometime soon, so even using the maxima brackets do i need to cut metal from somewhere else, i think I remember someone here selling brackets to just bolt on the e36, still need the dremel?
also what about the wade covers on the side marker ,I saw someone paint them black the reflective portion and cover it with a wade clear cover i thought they came as headlight and side marker cover,their was no say about cutting the wade cover.
Originally Posted by j30lex
Hi Guys
Great site.
Anyone know if there is a E36 headlamp conversion tutorial for the gen 3 anywhere?
Great site.
Click on the "links"...
Maxima30
Sep 7, 2015 06:13 PM
