View Poll Results: do you have a stuck antenna
Yes
45.61%
No
45.61%
Not sure if i have an antenna.
8.77%
Voters: 171. You may not vote on this poll
do you have a stuck antenna?
Old Apr 10, 2007 | 06:28 PM
evildoughboi's Avatar
for those ppl with stuck antennas, if its possible to even get it up, you can just clean off the dust with wd40. keep making it retract and extend and keep cleaning the dirt off that keeps coming out. when it goes in and out smoothly, wipe off all the wd40 and lub it with a bike lubricant; they are more resistant to road grim. mines worked for about 6 months before i had to do it again, even tho that thing was black.
one lesson i learned this winter: bike lubricant freezes/cogagulates at freezing temperatures. in this case, switch back to wd40. the more often u clean it, the easier it is each time.
im working on a way to remove the antenna and clean it from the inside.
i see at least a few each day (on all cars) and my dad keeps saying i should post this since he heard alot of ppl have this problem.
Old Apr 10, 2007 | 06:32 PM
maxitech's Avatar
Unplugged mine several years ago...got an MP3 player and teh radio sucks...
Old Apr 10, 2007 | 06:34 PM
Greeny's Avatar
¯\(°_o)/¯
Ehhhhhh...Sometimes,she work.....sometimes......She no work....
Old Apr 10, 2007 | 07:43 PM
hadman's Avatar
Imma lika da guy above ^. Me antenna lika me 3rd leg. Sometime go up... sometime... it a no go up.
Old Apr 10, 2007 | 07:45 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
er. yeah. mine no go up no more. mine no have connection to motor. me take out wires to motor. motor no go no more either. me antenna need new thingy inside. no sticky, but no worky either.
ooooh ---v
hadman
[Maximaniac]
Car: 1991 Black VG Auto, 1992 Black VE 5spd SE
j00 is 3vil...
Old Apr 10, 2007 | 07:52 PM
Gunther's Avatar
Mines bent back for extra speed - and it only goes up and down one extender thing so even if its stuck its still up i highly recommend this mod
Old Apr 10, 2007 | 08:18 PM
xx-Marshall-xx's Avatar
kthxbye2u
guys... i dot even know if mine even works or if its stuck down or what... is there a fuse?... i cant freakin find it
Old Apr 10, 2007 | 08:25 PM
Gunther's Avatar
it's probably either stuck or the plastic thing that makes it go up and down is busted
Old Apr 10, 2007 | 09:00 PM
Alex_V
I'm taking mine off and putting something reliable on there. I dunno if it'll be a manual antenna or a shark looking one like the new cars have...
~Alex
Old Apr 10, 2007 | 09:29 PM
u can probably wire it underneath the back metal thing that runs up from the trunk to the roof of the car. supposely theres an antenna in the back windshield as well, but might be connected to the defroster.
Old Apr 10, 2007 | 09:38 PM
[h2k]DotheDU's Avatar
1337 BR Max
Just recently mine stopped going completely down, but it goes up entirely when my radio is on. I'm guessing I should clean it now. :P
Old Apr 10, 2007 | 09:44 PM
Pearl93VE's Avatar
I can has?
Both cars, they are completely broken, I can't get the Antenna down on my 93VE past the 1/4 Mark. The GXE can go all the way down and all the way up, but only manually with my hands. Thinking about getting another one via ebay and just taking better care of it this time.
edit: also... what was up with the whole Pirate talk at the beginning, hah, wtf?
Old Apr 10, 2007 | 10:04 PM
ghostmax's Avatar
i fixed mine when i bought my car 3.5 years ago, and it hasn't broken yet *fingers crossed*
you can take it out and see if there's any broken plastic part of the mast that is causing the antenna not to retract.
Old Apr 10, 2007 | 11:31 PM
90pearlSE's Avatar
buy a hirshmann replacement - mine's worked great for 3 years on 2 cars.
Old Apr 10, 2007 | 11:59 PM
rmdl51's Avatar
White_Shadow
mine is not even connected to the motor, I dont need it, I don't listen to radio at all, just mp3 cd's :P
Old Apr 11, 2007 | 12:39 AM
arrrghhh's Avatar
mine worked GREAT until that panel got smashed.... shotty repairman fixed the panel, but the bent antenna is still unfixed. so the motor just goes and goes, i never listen to the radio anyways, but when the deck cycles thru the inputs it always tries to move the antenna. where should i disconnect the motor? i'd like to do that. just put the antenna all the way down & lay it to rest.
Old Apr 11, 2007 | 03:56 AM
Tom's Avatar
Tom
Mine worked reliably until late last year when we had a snow storm. I noticed driving to work, the antenna was still up after I parked the car and the radio shut off.
I came back out and the antenna was down. Over the course of next several days, I noticed it was up sometimes, down sometimes independent of the radio.
Then I went into my garage and noticed the antenna going up and down on its own about 1/4 height one evening. Now that was WEIRD! It wasn't just me, both my wife and daughter saw it. Like the antenna had a mind of its own. Key off and everything too.
I sprayed WD40 on the shaft and cleaned it. I was seriously looking at replacement antennas at the time, but after a couple of days, I noticed everything went back to normal.
4 months later, it still works fine.
Old Apr 11, 2007 | 05:12 AM
Michael's Avatar
Back in a 3rd Gen.
I voted no because I have not external antenna
Old Apr 11, 2007 | 07:45 AM
open the tool flap in the trunk, where the jack is, on the right hand wall of your trunk. Then reach back (hand will go toward the front of the car) in there, there's a box thing, and a harness. disconnect that harness. I think there's 2, actually... but one is the signal for the antenna, the other is the motor. i did this 9 months ago.. sorry to be vague but i never really look at that particular part of my car...
Old Apr 11, 2007 | 08:54 AM
Pervis Anathema's Avatar
You too? What are the odds?
Old Apr 11, 2007 | 09:22 AM
92 Max's Avatar
I got tired of the stuck up feature of the automatic antenna and changed it to a cheap, metra manual antenna and now I have no problems whatsoever with the antenna. This electric antenna on the Maxima seems to be a particularly problematic and expensive one. Two excellent reasons to dump it.
Old Apr 11, 2007 | 10:09 AM
Bullard_07's Avatar
Yea mine got tha antenna on the back window but just like capedcadever said is the easiest way to look and find the damage. I work at NAPA and some one in a 96 maxima came up there bout 2 months ago and we did that same exact stuff.....go get an iPod and Av cables for your Cd player, screw the radio anyway!
Old Apr 11, 2007 | 10:55 AM
maximo-SE's Avatar
i had this problem in my 94 camry. i literally had to replace it. wd 40 didnt work for me.
Old Apr 11, 2007 | 11:06 AM
if u can get the antenna up manually, u can still clean it and it should work fine, even if you think its stuck.
Old Apr 11, 2007 | 01:50 PM
slickblack94's Avatar
mine was stuck,then I replaced the mast, now works like new!
Old Apr 11, 2007 | 02:57 PM
Darkwing48's Avatar
Mine over retracted itself. I'm not sure if it was here, but I need to remove the antenna to put a limiter on it. does anyone else have this prob?
Old Apr 11, 2007 | 03:51 PM
maxedj30's Avatar
I think there is a plastic long coil (inside) which can break and that what stops the antenna from going all the way down or up.
Old Apr 11, 2007 | 05:00 PM
yeah, that broke on mine, PLUS the whole antenna is a POS anyways. it is hooked backward because i lined up all the messed up-ness in the joints and let it sweep back..
Old Apr 11, 2007 | 05:16 PM
Wolfe's Avatar
LOL sounds like my wife!! LOL
Old Apr 12, 2007 | 09:55 AM
Jon94SE's Avatar
My HU wasn't getting any signal whatsoever even though the antenna was hooked up. Since the motor is getting 12v and doesn't move or make any noise I think the motor is dead. I just unplugged the signal cable from the trunk side and it started getting reception for some reason after that.
Old Apr 12, 2007 | 10:16 AM
Tquick's Avatar
Mine works mostly, although sometimes it doesn't go all the way up, and sometimes it doesn't go all the way down. I cleaned it with WD40 at the beginning of the winter, but perhaps I didn't do a good enough job, so I think I will give it another cleaning and lubricating with the WD40 and see if that helps any.
Old Apr 12, 2007 | 11:44 AM
ogah_yellow's Avatar
Mine got stuck in the up position, bent, then broke off. I hope that that doesn't happen with my 3rd leg...
Old Apr 12, 2007 | 05:32 PM
jlars205's Avatar
Mine works, but I don't like it much. It probably the one thing other than the wheels that really dates the car. I'd much rather have a concealed one.
Old Apr 12, 2007 | 10:16 PM
Hectic's Avatar
Just do this
I saw that today and thought about this thread. I keep a cheap digicam in the car at all times in case I see something interesting on the road.
Old Apr 12, 2007 | 10:31 PM
i believe u should be able to wire an antenna on the inside of the car frame without much interference. in addition, you might be able to wire the antenna on the trunk lid, but since the trunk is closed all the time (hopefully) and how radio reception works, it probably wont work.
and about that tailfin, that is totally pointless. its a FWD. if he had it on his hood it might work, but then it would look stupid. maybe a lower one like the 4th or 5th gen looks kinda cool, but thats just too much
Old Apr 12, 2007 | 11:28 PM
Cliff Clavin's Avatar
Way out West
Mine works perfectly, just like new.
I rarely listen to the radio, though.
Old Apr 13, 2007 | 04:03 PM
Greeny's Avatar
¯\(°_o)/¯
Mine only fails in cold weather..
Works every time when it's above approx. 60 degrees...
Old bones creak i guess...
Old Apr 13, 2007 | 05:23 PM
Mikxima's Avatar
My antenna goes up and down all the way, but once it reaches the top, the motor that drives it continues to crank away on it. I don't even know how long it lasts, because I'm usually driving and forget about it.
Old Apr 14, 2007 | 11:20 AM
heresmymind
Yeah... mine stopped working and wouldn't go all the way down unless i nudged it. but about 3 weeks ago it randomly started working completely. Random Self Fix FTW
Old Apr 15, 2007 | 11:40 AM
Litowcas's Avatar
broke mine off in a car wash.. bummer
