Something else we have on newer max's
Originally Posted by Cliff Clavin
I have had one break on each front wheel. I thought ours were kind of buttery. Both broke fairly easily.
I have had a left front break also,i just left it alone until i replaced my entire front hub unit when the wheel bearing crapped out..
Originally Posted by Badman_Maxima
Wat we have over the newer max's also , is the full out Digi-Dash and Heads up display, and of course SONAR SUSPENSION III & the Tranny tweak switch hehehe!
3rd Gens fo lyfe!!!
3rd Gens fo lyfe!!!
3rd Gens fo lyfe!!!
3rd Gens fo lyfe!!!
HUD - same as above...replacement windshields are also very $$
sonar suspension - very very $$$ to replace worn struts. most swap in non sonar units.
i like the 3rd gen like the next guy but there was a reason those items were scrapped from the 4th gen and up...besides the point that the 4th gens were built when nissan were about to go under.
Originally Posted by DanNY
Digi dash - very problem prone...flickering or no display
Digi dash - My car has had it for over 180k miles, and I get none of the above.
HUD - Same thing
Sonar Suspension - THAT is ridiculously expensive. Stealership wanted something like $600 PER strut. Thats when my car got KYB's in the front. I want Konis now though.
Originally Posted by Dhunterx
Umm
HUD - Same thing
HUD - Same thing
there are companies that address these issues..here's one of them...
http://www.mrwhizard.com/services2.cfm
1989-93 Maxima Digital Dash - Symptoms: Dark, may come on when warm and/or speedo and odometer not working. HUD not working OR Temp and Fuel gauge works but speedo/odometer/tach gauges are dark. If speedo display is working, it may show speed up to 40 mph when the vehicle is standing still. Repair Cost $189
no way shape or form i'm endorsing the company..it's only for reference.
Originally Posted by Hollywood!
for Nissan being close to its death, the 4th gen, i would have to say is a great car, and im still amazed at how they did it, even while on a downward spiral.
the rest of the car was cheapened to save cost compared to the 3rd gen.
somehow they pulled through it and then renault signed up.
maybe not in FL...but the digi dash and the HUD are problem prone in the colder regions where the temps really drop and i believe the solder on the contacts starts to get loose...similar to the mystery fading clock. the S13 cars with digital dash/HUD also have the similar problem. if it's not happening to you then you're lucky or maybe it was repaired in the past but IT DOES HAPPEN.
Ive had the Digi Dash and Sonar system working for 9 years now , still no problems.... The only thing i had to change were the struts, which i got used from Japan Auto here in Toronto. So Far so good. can't complain. Knock on wood.
are you the first owner of the car?
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
