wiring question
wiring question
does anyone no if the 3 wires running on top of the passenger control arm/right motor mount connects to the reverse switch or has any thing to do with the reverse lights?
yeah those are colors. i wont b able to trace them until i pick my car up 2morrow. the wire got clipped but im not receiving any codes. when i throw my car in reverse the lights dont work and im not sure if this happened before or after clipping of wire
i don't know where those reverse light wires are but i am pretty sure that they run along the floor inside the car
as for the 02 sensor... you can see it if you look under the car, you just can't replace it without lifting the front of the car.
so being that the o2 sensor is not connected shouldnt i throw a code
if the wires are all cut there should be a code. the no-error code is a 55. are you sure you are checking your codes properly?
Originally Posted by capedcadaver
yeah that confuses me. you should have a 33... i had a 33...
you may have the "sensor connected" wire still intact, and the signal-to-ecm wire cut...
thus no code
thus no code
ahhh yes. i didnt unplug anything so that may b it. so have any clue about the reverse lights? ive tried everything. new bulbs cleaned contacts changed lighting assembly but still nothing and all other lights work
is that the little box under the shfter on the driver side. i have an auto tranny
The Frye
Sep 2, 2021 11:03 AM
