car dies with radiator fan
Old Apr 28, 2007 | 12:25 PM
mooze's Avatar
serious problem. whenever the radiator fans come on my car dies. driving not driving whenever. need this fixed asap
Old Apr 28, 2007 | 01:23 PM
gapboi210's Avatar
Radiator fans draw a lot of amps. Start with the basics, battery and alternator. Sounds like when they are turning on the car can't provide sufficent power. Check you battery connections, make sure they are clean and tight. Wouldn't hurt to look the fuses and relays too.
Old Apr 28, 2007 | 02:23 PM
mooze's Avatar
i think it happened because of my audio equipment. its now running fine without the equipment on
Old Apr 28, 2007 | 03:49 PM
Greeny's Avatar
¯\(°_o)/¯
Hows your idle normally,low?
If not,it maybe a bad coolant temp sensor..not sure though..
Old Apr 28, 2007 | 06:58 PM
mooze's Avatar
idles great hasnt happened again so far
Old Apr 28, 2007 | 07:07 PM
Greeny's Avatar
¯\(°_o)/¯
I would check all the sensor harnesses for corrosion[green crap].pick up a small wire brush set and some brake parts cleaner from walmart to clean the connectors with...
Then report back with your results....
Old Apr 28, 2007 | 07:15 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
let the radiator fans come on, then quickly flick on your system. see if it kills it again. that'll be your definitive test. then you'll want to make sure your alt is fine and ALL that the connections beween car, battery, and alternator are intact and free-flowing.
Old Apr 28, 2007 | 07:30 PM
Matt93SE's Avatar
STFU n00b!
what he said for the most part.
sounds like you've got a loose wire or something between your alternator and battery. check them to make sure they're not corroded or damaged.
also check battery to chassis ground and chassis to engine.
Lakersallday24
Jun 16, 2019 01:35 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
acw
Aug 7, 2015 04:20 PM
