no acceleration!!!! HELP
Old Apr 28, 2007 | 12:27 PM
mooze's Avatar
when i start the car and ride off everything is fine after i slow down to make a turn or stop theres no power. car wont get over 4000rpm and it struggles to get there. any suggestions
Old Apr 28, 2007 | 02:56 PM
Kountz430's Avatar
bald aggression est 78
try checking your maf and tps
Old Apr 28, 2007 | 10:21 PM
gapboi210's Avatar
is it mis-firing? Burnt or broken spark plug wire maybe?
Old Apr 28, 2007 | 10:34 PM
maxitech's Avatar
You need to be more specific.
Old Apr 28, 2007 | 10:43 PM
mooze's Avatar
after stopping or slowing down power seems to disappear. will go to about 2000rpm and will take forever to get up. if i floor it it wont get up or rpm increases and speed stays the same. ill try to make a video
Old Apr 28, 2007 | 10:48 PM
maxitech's Avatar
Most likely a sensor of some type...Also check you normal tune-up stuff like plugs, wires, distributor cap / rotor, fuel filter, 02 sensor, MAF connection, etc...
Old Apr 28, 2007 | 10:52 PM
x91max
its the tps dude mine does the same exact thing. i think you can buy a rebuild kit for it just be careful when taking it apart they made the screws out of like paper and they can break just by pokin it.
Old Apr 28, 2007 | 10:59 PM
maxitech's Avatar
I could be wrong, but I didn't think TPS's went out that often.
Old Apr 28, 2007 | 11:03 PM
x91max
ive rebuilt mine twice in 200k miles
Old Apr 28, 2007 | 11:13 PM
Alex_V
rebuilt? They are pretty much sealed, just replace it with a junkyard part.
to OP- try maf cleaner if there isn't a junkyard close. "MAF cleaner" ONLY carb cleaner will kill your maf.
~Alex
Old Apr 28, 2007 | 11:20 PM
mooze's Avatar
im goin to test it 2morrow. kinda pointless in rebuilding it tho. just replace. i tested my camshaft position sensor already and its fine. ? i have an 02 sensor thats not pulsing back to the ecm. does anyone think that could cause the problem?
Old Apr 29, 2007 | 03:42 PM
92 Max's Avatar
You're saying that the engine speeds up, but the car doesn't? What type of tranmission do you have? Sounds like it's slipping.
Old Apr 29, 2007 | 04:57 PM
gapboi210's Avatar
how is it running when it is trying to reach 4000? Is it running really rough like it is missing? Maybe it is running in limp (safe) mode. You are going to have to be more detailed.
Old Apr 29, 2007 | 05:23 PM
Cliff Clavin's Avatar
Way out West
My first suggestion is to test your ECU for codes. Please do that first to see if anything comes up. Our cars kind of suck in that the codes don't come up that often, but you should at least check. Mine did throw a code for coolant temp sensor when that went bad.
I believe the MAF limp mode is more like 2500 or 3k rpm, so that's not likely the problem.
My guess is going to be one of your sensors, coil pack(s) or clogged cat (not that likely). Another thing to check is fuel filter and fuel lines/fuel pump. Yes, these are a lot of things to check, but your diagnosis is a little vague.
Oh, Maxitech, it says in his profile that he has a 93 SE -- that means no distributor, cap, rotor, plug wires, etc.
Old Apr 29, 2007 | 09:37 PM
mooze's Avatar
i changed the map sensor. that did a great deal of work. picks up fine now. i still dont think it where its supposed to be.
Old Apr 29, 2007 | 10:44 PM
gapboi210's Avatar
huh? you said it picks up fine now but it still isn't correct? so did it work or not?
Old Apr 29, 2007 | 10:47 PM
x91max
map sensor or maf?
Old Apr 30, 2007 | 08:47 PM
mooze's Avatar
sorry maf sensor. heres the deal now. it not just lags on take off. lags until about 3000 rpm and then its gone with the wind
Old Apr 30, 2007 | 08:52 PM
Pearl93VE's Avatar
I can has?
My car felt dead like that when I first got it. Felt like it didn't even move until around 3500RPM's. I replaced the MAF and it helped quite a bit (Along with the addition of a Cold Air Intake) But it still kind of felt dead in low RPM's. I didn't really do anything else to it other than normal maintenance (Oil Change, Sea Foam, Injector Cleaner, Clean IAC, MAF, EGR, etc.) Everyone swore up and down it was a bad injector, but it just went away after a few weeks or so. I think in my case the car was sitting for a while...
Old Apr 30, 2007 | 09:02 PM
mooze's Avatar
my car was sitting for a while too. years actually. im not sure if mine is bad injector or not cuz when i unplug one barely makes a difference idle. when gas is givin makes a big difference. i think mine may b clogged or so. i gave them a synthetic treatment today. see if that makes a difference
Old Apr 30, 2007 | 09:09 PM
maxitech's Avatar
Be careful what you add to the fuel system...The injectors are suicidal if you live in an area with ethanol added to the gas! Treatments may do more harm than good.
Old Apr 30, 2007 | 09:20 PM
mooze's Avatar
wouldnt that be places like large cities where emissions are a big issue?
Old Apr 30, 2007 | 09:36 PM
Pearl93VE's Avatar
I can has?
yeah, we don't have to worry about ethanol too much here in the South
Old Apr 30, 2007 | 10:11 PM
maxitech's Avatar
Meh, ATL is big town.
Old May 1, 2007 | 12:14 PM
15yrslater's Avatar
I hate to ask a really dumb question, but my VE seems to be doing about the same thing. A new injector helped with a rough idle, but it still seems a little weak.
So, what is involved in replacing the MAF sensor? (I was going to ask what MAF stood for, but I at least googled it to find out what it is). Is there another post that anyone can refer me to?
Old May 1, 2007 | 01:32 PM
maxitech's Avatar
The MAF is the thing on your intake assembly with the plug going into it...Try cleaning the plug and connection before replacing it...There are many used MAF's for sale out there (new ones are crazy expensive)...In fact, a lot of us keep a spare one around...
Old May 1, 2007 | 01:39 PM
Greeny's Avatar
¯\(°_o)/¯
Is it weak in low end power[below 3500rpm]?
If it is,it may be a bad knock sensor...
Location of maf sensor[pic is of a vg,but the ve maf is in about the same area]
removal of the maf is super simple,just take a look at it..four screws/loosen a clamp/remove wire harness...done..
Old May 1, 2007 | 01:45 PM
15yrslater's Avatar
Low end power is definitely where it really struggles. In an earlier post, someone seemed to mention that a new MAF would correct that. I'd rather replace the MAF than the knock sensor, seeing that I could actually attempt the MAF.
Old May 1, 2007 | 01:47 PM
15yrslater's Avatar
Also, do the VE & VG use the same MAF?
Old May 1, 2007 | 01:53 PM
Greeny's Avatar
¯\(°_o)/¯
I seriously doubt the maf is your issue,sounds like a bad k/s...
Well,you could bypass the k/s,but you must ABSOLUTELY run nothing but premium fuel or you will destroy your engine...all it takes is a 470k resistor in the k/s plug harness...But replacing it would be better..
Or you could drive it over to me and i will replace it for you..
Old May 1, 2007 | 02:28 PM
mooze's Avatar
ok ok ok. so today comes out to be the worse so far. after treatment car was running fine but now i have a dead alternator. b-4 car dieing it seemed to lag on take off again. think its because of alternator?
Old May 2, 2007 | 07:29 AM
15yrslater's Avatar
The thought had crossed my mind... Where in TN are you?
I'm assuming it is the knock sensor. Does that also cause it to lag under load? As in, at a stop, you floor it and it kind of takes its good old time thinking about going? (It's an auto)
Old May 2, 2007 | 08:10 AM
Greeny's Avatar
¯\(°_o)/¯
Pm me on this issue when you reach 15 posts..
Yeah,when the knock sensor fails,the ecu will automatically retard the timing[to about the 3500rpm area] to protect the engine from detonation[spark knock]..the end result is a severe loss in low end power..
Old May 2, 2007 | 08:19 AM
15yrslater's Avatar
It sounds like the KS is definitely my issue, then. Thanks for the info. I'm moving on, seeing that I feel like I kind of high-jacked this thread.
I'll shoot you a PM soon.
Old May 5, 2007 | 10:53 PM
mooze's Avatar
im not sure what my cars problem is yet. i havnt been driving it so today i changed the transmission fluid (brownish-blackish color) and added so lucas in. i then started it up and tested. now take off is perfect.......until i stop or slow down to make a turn or wutever. wtf is going on. heres a video of take-off after a stop with the pedal to the floor. http://s6.photobucket.com/albums/y21...=VIDEO_019.flv as u see its not that great.
Old May 6, 2007 | 01:50 AM
Greeny's Avatar
¯\(°_o)/¯
Well,after watching the video i noticed you have a gxe maxima [VG SOHC ENGINE] Not a SE....Unless you have swapped your instrument cluster out with a gxe?
Old May 6, 2007 | 06:21 AM
internetautomar's Avatar
mod or sell?
that's an SE cluster at night, wayne.
Old May 6, 2007 | 07:32 AM
mooze's Avatar
if you wathced carefully you would see where the speedo goes over 125 at about 0:20. ive never seeen a gxe with that on the dash. video was shot at night tho
Old May 6, 2007 | 04:16 PM
Greeny's Avatar
¯\(°_o)/¯
It was early,i was tired...
Old May 6, 2007 | 04:45 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
but the green glow? i heard the SE cluster ran white glow (or did I hear wrong?), so did you put green lights in, Mooze?
