Exhaust note change when in water!
Old May 1, 2007 | 10:10 AM
Maxima Man's Avatar
Hey guys I got a odd question but whenever I hit a puddle of water on the side of the road my exhaust note becomes much louder for about 30-60 seconds after the impact of the water. So my question is what causes the sound is water getting in the exhaust ??? I don't have a clue!
Thanks for any input!
Old May 1, 2007 | 10:25 AM
Matt93SE's Avatar
STFU n00b!
sounds like you've got a crack in your exhaust somewhere.
splash water on it and the metal contracts, making the crack bigger and more noise.
Old May 1, 2007 | 10:30 AM
Maxima Man's Avatar
Well I have replaced my Y-pipe with a warp speed performance one and I have a 2 month old cat back new all pre welded so no cracks there. The only thing that is still old is the exhaust manifolds and the cat.
I also have a exhaust rattle problem at about 2100 RPMs and the cat shield is off so the only other shield I can think of is the shield that is on the exhaust manifold itself. I think thats the shield that is rattling.
Old May 1, 2007 | 10:35 AM
Matt93SE's Avatar
STFU n00b!
could also be the guts in the catalytic convertor rattling, or parts of it inside the muffler.
I had a cat explode on me a few years back (after it rattled for months), and when it did, it launched marble-sized chunks of cat into the muffler, which got stuck inside if and rattled around from then. I finally got pissed and bought a new exhaust. noise gone.
and just because it's new doesn't mean it's not damaged or leaking. it could be a cracked weld, it could be a cracked resonator (you'd be amazed how many I've seen), or it could be a bad gasket on either end of your cat where things mate up. I've seen them all leak over the years.. on my car and others.
Old May 1, 2007 | 10:46 AM
Maxima Man's Avatar
Well then I guess I can try to tighten the gaskets on either side of the cat but when I installed the cat back I had the car on a lift and I remote started the car and there were no leaks.( I went around with my hand to feel any leaks but none were found ) So water couldnt be getting as high as the exhaust manifolds could it I was kind of ruling them out due to there location.
I really don't think its the cat rattling although I have never heard one rattle but It sounds like a heat sheild tack weld has broken and is rattling.
The welds in the cat could be cracked how could I check to see ?
BTW I put new gaskets on either side of the cat !
Old May 1, 2007 | 11:28 AM
Matt93SE's Avatar
STFU n00b!
If you cranked them down too hard, especially on the Y pipe to cat, you can bend the flanges and they will leak. sometimes not right at first, but a week or more down the road, they'll develop leaks.
Old May 1, 2007 | 11:39 AM
Maxima Man's Avatar
o well I don't think they were that tight
So has anyone else had this problem and had a solution other than exhaust leak?
Old May 1, 2007 | 11:40 AM
Greeny's Avatar
¯\(°_o)/¯
About a week after i had my warpspeed pipe istalled,one of my exhaust hangers broke about mid rear on the car[in the bend around the gas tank]
It was rattling around against the pipe..so check this area for a possible broke hanger...And while your under there,give the entire exhaust system a good inspection for obvious problems...
Old May 1, 2007 | 03:16 PM
Maxima Man's Avatar
Ok I will check it out and look for exhaust leaks.
Thanks !
captchaos
Mar 15, 2016 12:18 PM
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
