sohc alternator on dohc
Old May 1, 2007 | 02:29 PM
mooze's Avatar
could this be done?
Old May 1, 2007 | 02:50 PM
ColombianMax's Avatar
I believe the SOHC alternator is 60 amps while the DOHC is 90 amps but I could be wrong... They def are different part numbers and cost different price. Sorry that doesnt answer fully your question but gives you a bit more info
Old May 1, 2007 | 03:04 PM
mooze's Avatar
no both are 90 amp
Old May 1, 2007 | 03:25 PM
What is your source for saying they're both 90 amp?
Old May 1, 2007 | 03:39 PM
Jbr8k's Avatar
Originally Posted by mooze
no both are 90 amp
VG- 90 amp Alt
VE- 95 amp Alt
They bolt up differently, I've tried..
Old May 1, 2007 | 05:35 PM
Tom's Avatar
Tom
If you have a Chilton's Manual for the 1985-1992 Maxima , look on page 3-12.
There's a section on ALTERNATOR AND REGULATOR SPECIFICATIONS. Here's what it reads for the 3rd gen
VG alternator charges
23 amp @ 1300 RPM
63 amp @ 2500 RPM
84 amp @ 5000 RPM
VE alternator charges
34 amp at 1300 RPM
80 amp at 2500 RPM
91 amp at 5000 RPM
Old May 1, 2007 | 05:45 PM
Greeny's Avatar
¯\(°_o)/¯
Amperage rating's are of no use here,the casing's are completly different from ve/vg alty's...In other words..the ve alty wil not bolt up the the vg engine/vg alty will not bolt up to the ve engine...
Get the alty specified for your engine type..period..
Old May 1, 2007 | 05:52 PM
hmm everyone's got different information as to how many amps they both have. So does anyone know for a fact what the amp ratings are? just curious..I already know that they're completely different but I remember reading at work that the VG alternator had way less than the VE but now I'm confused.
Old May 1, 2007 | 06:03 PM
Greeny's Avatar
¯\(°_o)/¯
VG alternator
VE alternator
Old May 1, 2007 | 06:05 PM
mooze's Avatar
that price is not bad....will be looking into
Old May 1, 2007 | 06:06 PM
mooze's Avatar
i searched and most that i found were 90 amp
Old May 1, 2007 | 06:12 PM
Alex_V
90/95 is what Ive always found....
Alot of other/older nissan cars can use the maxima's alt for an upgrade, It basically bolts up to a 240z-280zx. And I thought I read last time some one posted they used a VE alt on a VG? Doesn't look hard to make a bracket. How does the VE's plug look?
~Alex
Old May 1, 2007 | 06:18 PM
Greeny's Avatar
¯\(°_o)/¯
~Alex
If you would look at the pictures provided,you will see that the clocking of the mounting bolts are different from ve/vg...
What would be the gain of trying to to mount a different alty to it anyway?
Why go through all the trouble of fabricating a bracket and and cutting/rewiring the plug for 5 amps?
Like i said previously,just get the right alternator for your engine...
Old May 1, 2007 | 06:19 PM
internetautomar's Avatar
mod or sell?
they can be swapped with one another IF you don't mind some jerry rigging.
it has been done before.
SSSSSSEEEEEEEAAAARRRRRCCCCCHHHHHHH
Old May 1, 2007 | 06:29 PM
Greeny's Avatar
¯\(°_o)/¯
WHAT WOULD BE THE POINT IN RIGGING UP A DIFFERENT ALTY???
It just seems like a rediculous idea to rig up a ve/vg alty to either engine,..
Why not just get the right damn alty for your engine type? It's a 15 minute job to swap them like they are....Who knows how many hours to fab up a different bracket/plug harness for what reason?
Old May 2, 2007 | 07:20 AM
mod or sell?
it was done because the guy had one or the other one sitting around.
I think Vans did it.
TallTom
57
Oct 14, 2025 05:16 PM
