No High beams ! Need Help
Old May 12, 2007 | 08:19 PM
Maxima Man's Avatar
Well I was driving fast down our road tonight and my high beams cut off all together and I was like oh no so I flipped the switch to low and they worked fine then I switched back to high and just the left beam was on so I was confused then turned back to low and back to high and now only the right is on ! So I am so confused I know both bulbs are fine not going to replace on a whim they are silverstars and I like them. So sometimes after playing with the lights I can get one light to shine but most of the time no light.
The problem only effects the high beams so what could I check are there independent relays for each headlight ? why would both act up?
Thanks for any help!!
Old May 13, 2007 | 01:40 AM
Greeny's Avatar
¯\(°_o)/¯
Most likely the headlight switch contacts need cleaned...
You can try to clean the switch
http://forums.maxima.org/showthread.php?t=434582
Or just replace it with a new unit...
Old May 13, 2007 | 03:32 AM
93SCMax's Avatar
98 SE
I agree with MyGreenMax94. I had a similar issue and replaced bulbs and checked relays. That didn't fix it. The combination switch on the steering column had dirty contacts. Just clean them with electrical contact cleaner, or use the attached write-up, and you should be back in business. It's a pretty easy job.
Old May 13, 2007 | 08:04 AM
Maxima Man's Avatar
Well dosent that switch just cut both headlights on or off or is there a switch for each headlight your are closing when you turn the high beams on because if there are independent switches then that would be the reason why i only have one light on sometimes.
But i will take it apart and clean everything up and see what i got thanks for the write up greeny!
Old May 13, 2007 | 08:30 AM
Matt93SE's Avatar
STFU n00b!
each headlight (right, left / low, high) has individual contact inside the switch. it's a very common problem. mine did the same thing a couple months ago.
remove switch and clean and see what happens.
If that doesn't fix it, swap your bulbs left to right and see if the problem follows the bulbs or not.
then come back and tell us what it's doing.
Old May 13, 2007 | 10:14 AM
heresmymind
do yourself a favor and make an upgraded harness. i think Craig Braces page has a write up. i had to do one for my hids/bixenons but when i had one for the halogens they were brighter and didn't dim with heavy bass load from my subs
Old May 13, 2007 | 11:39 AM
Maxima Man's Avatar
Well I cleaned the all the terminals but the high beam terminals had black dots on the copper contact surface so I scraped it off with a tiny screwdriver and then sprayed with electronis cleaner and now my problem is solved.
Heresmymind - if I were to redo the headlight wiring harness where would I start of course with the bulb connector but how far into the harness ?
Where do they end up?
Old May 13, 2007 | 03:49 PM
Liquidnails's Avatar
Thanks for posting this fix. I've been having the same problem off and on for a month or so and not being able to figure out the problem has really been driving me nuts.
Old May 14, 2007 | 12:38 PM
heresmymind
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
