Changing Camber and Caster without aftermarket bolts
Old May 21, 2007 | 09:14 PM
OnTheRoad's Avatar
Is there a way to change the camber and caster with the factory bolts installed?
My left Caster angle has was 0.2 deg. 6000 miles ago and is now 0.1 deg. It out of spec (0.5 to 2.0).
Toe seems to be going more positive (hitting the curb?).
Measurements were with 3/4 tank of gas today. I don't remembr how full the tank was the previous alignment. But the last two left casters were out of spec on the last alignments, but 0.5 degrees less than the right caster.
OnTheRoad
Old May 22, 2007 | 04:20 AM
Greeny's Avatar
¯\(°_o)/¯
The camber angle is non adjustable on these cars,unless you have installed camber bolts on the struts,caster angle is also non adjustable...
Sounds like you have worn out control arm bushings....
Old May 22, 2007 | 06:27 AM
Matt93SE's Avatar
STFU n00b!
As greeny said, it's not adjustable from the factory. If your alignment is changing, it's either due to potholes & curbs, or a part in your suspension is worn out. tie rod ends, ball joints, suspension bushings, etc.
Old May 22, 2007 | 08:29 AM
maxitech's Avatar
How does the alignment shop adjust the camber and castor then?
Old May 22, 2007 | 08:38 AM
Greeny's Avatar
¯\(°_o)/¯
Ummm...They don't,the only alingnment adjustment that can be made to a stock 3rd gen suspension is toe in,via the tie rod ends..
Old May 22, 2007 | 08:53 AM
maxitech's Avatar
Hmm...sounds like I need some camber bolts on the front...The inner half of my tires wears faster than I'd like.
Old May 22, 2007 | 08:55 AM
maxitech's Avatar
Who makes them / what is the best brand to get (front)
Old May 22, 2007 | 09:15 AM
Alex_V
read nForces thread about it...
~Alex
matts95max
Apr 23, 2025 10:44 AM
The Wizard
24
Oct 1, 2015 08:47 PM
dcam0326
Sep 18, 2015 04:52 PM
jcvgn
Sep 13, 2015 11:42 AM
ag90fox
Sep 9, 2015 12:22 PM
