Bose Radio Issue...
Old Jun 2, 2007 | 09:24 PM
RayRey21's Avatar
Bose Radio Issue...
Hey fellas..., I have an issue with the Bose Radio in my 94 GXE. We seem to be getting power to the radio because the buttons (power, cd, presets etc) are illuminating, however, it seems to have a mind of its own as far as functionality. Sometimes it turns on, sometimes I have to slap it.
Any suggestions or help??
Thanks in advance!!
Old Jun 2, 2007 | 09:48 PM
Cliff Clavin's Avatar
Way out West
You have to hit the actual HU? That sounds like a bad connection at the HU itself. Probably the wiring in the back.
These Bose systems are notoriously bad about the amplifiers and speakers conking out. Each speaker has it's own seperate amp located at the speaker. Most people that can afford it, yank out all of the Bose and replace it with something aftermarket.
Old Jun 2, 2007 | 11:30 PM
RayRey21's Avatar
I've taken out the HU.....cleaned connections......everything seems ok.....it was working a yesterday but just stopped.....the stock setup is decent...i'm happy withit...not looking to spend money on a radio upgrade.......so if you guys can offer any suggestions I'd appreciate it....thanks!
Old Jun 2, 2007 | 11:38 PM
mooze's Avatar
sounds as though you have a bad hu. may be bad connection somewhere on the board of unit
Old Jun 3, 2007 | 06:43 AM
internetautomar's Avatar
mod or sell?
unfortunately after 13yrs the "bose" H/Us and amps have all developed problems. The only question is did someone fix them yet.
you can fairly cheaply swap out the bose for cheap aftermarket setup.
get a cheap H/U >$100 some cheap 6x9s >$30 and some cheap 5 1/2s >$30 and a piece of MDF >$8 total cost $170 max.
I'm sure you could get even cheaper (I get ads every now and them for $1-5 speakers) if you really don't care about sound quality much.
Old Jun 3, 2007 | 08:24 AM
RayRey21's Avatar
will other Nissan Bose HU's fit in my 94?......or should I say "which" HU's from Nissan will fit.....I've seen several on ebay that appear to be the same size but which years can I consider? obviously 89-94 bose will plug and play......any other years as well?
Old Jun 3, 2007 | 08:28 AM
RayRey21's Avatar
I found this site snooping around...pretty cool.....
http://www.carstereohelp.com/nissan.htm
Old Jun 3, 2007 | 09:01 AM
RayRey21's Avatar
apparently the problems I am having with my radio is common....they suggested that I upgrade to a 97-99 bose unit...but must buy a $35 wire harness.....
Old Jun 3, 2007 | 09:13 AM
prappl's Avatar
I never understand people who want to replace a factory stereo with a factory stereo. You can get a better unit that will have the features you really want for less money.
Personally, I'm looking at a DVD/navigation unit, though I don't know if I'd want a screen that low...
Old Jun 3, 2007 | 09:54 AM
mod or sell?
Personally I prefer OE stereos because when they work, they sound pretty good. and they don't get stolen!
Old Jun 3, 2007 | 09:57 AM
mooze's Avatar
i 2 would recommend and aftermarket hu. u dont have to change your speakers if what cliff says is correct. i know most am hu have a 4ohm output while the bose speakers are 1ohms.
Old Jun 3, 2007 | 10:11 AM
RayRey21's Avatar
simply put I like a stock look...not big on aftermaket stuff anymore.....some things I am but not radio's......the stock HU was fine until it decided to stop working.....dont want to change the head unit then have to buy other harnesses and wires etc......just want a simple stock HU...thats all.
with that said I "still" have a non-working HU.....I'll just plug it back in and see if it turns on by itself again.......like my sig says, its a daily beater, nothing special...
Old Jun 4, 2007 | 08:20 PM
RayRey21's Avatar
my HU is shot....this thing sucks.....have a CD stuck inside too....just burned that disc too.....wont turn back on......not sure what I want to do next.....very quiet in my car.......i took the HU apart but had no idea what I was looking for...might have to "buy" I cheap aftermarket HU.....so do I need to rewire if I get an aftermarket HU?? new wiring to the speakers?? bypassing the stock amps?? what is the details fellas!
Old Jun 5, 2007 | 06:51 AM
mod or sell?
if you go aftermarket on the H/U you either need an adapter to adjust the output of the aftermarket stereo to the bose amps inputs, or replace the speakers with aftermarkets that will be compatible with the H/U
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
