Soo..I changed my timing belt today....
Old Jun 14, 2007 | 07:06 PM
TWINTRBO's Avatar
Interesting job, fairly straightforward and tons more room than my VR4! (2 less cams help too ) So only 2 things that went wrong, I pushed the passenger side cam seal in a little farther than I intended to and I somehow goofed on one little gold screw behind the cam gear so it got left out. I cant believe how loose the old belt was either, I guess 14 years will do that! The car only has 63K on it and it was all original parts, so I tossed in a new Timing belt, tensioner pulley, water pump, thermostat, hoses and drive belts. Im the second owner and shes found a good home now, cant wait to drive it more aggressively now that I know it wont blow up. Good thing I went easy on it, it probably would have let go.
Old Jun 14, 2007 | 07:34 PM
plaman88's Avatar
clean *** max
nice
Old Jun 14, 2007 | 07:59 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
if that bolt goes on the plate behind the cam gear that attaches it to the head then it should be ok
Old Jun 14, 2007 | 08:54 PM
Matt93SE's Avatar
STFU n00b!
check to make sure the other three gold screws are good and tight then. I've seen them come loose and wreak havoc on the timing belt. eek.
Old Jun 15, 2007 | 05:38 AM
TWINTRBO's Avatar
Yeah its the one that holds the back plate to the head. I somehow put the bolt in the hole for the front cover bolt which I realized way too late in the job to go back and try to fix. I torqued em down so the others arent going anywhere, thanks for the advice. Thanks plaman88, its not as clean as the sig makes it look though. I think I will get it detailed this summer since it hasnt been waxed in a LOOOOONG time. On the plus side its all original paint so it should come up nice. Anyone know if an SE exhaust will fit a GXE?
Old Jun 17, 2007 | 04:26 PM
Quickywd01's Avatar
How long did it take you to complete the change?
Old Jun 17, 2007 | 06:45 PM
TWINTRBO's Avatar
I did it over the course of 2 days just because I didn't feel like killing myself. Total hours would be about 9, including 2 trips for tools/stuff, having to take the belt cover off again for a lost socket, etc.... Cutting out the nonsense, 6 hours would be a good estimate. Thats including everything from getting tools together until I turned the key and went to test drive. I also changed the cam seals, replaced the water pump, thermostat and all hoses.
Old Jun 17, 2007 | 10:50 PM
Quickywd01's Avatar
I wanted to remove the belt cover to inspect it since I don't know it's condition at 100k miles and 13 years. It's supposedly changed. But it looks like it would take a long time to get to it and it's a tight area.
Old Jun 18, 2007 | 09:25 AM
Matt93SE's Avatar
STFU n00b!
you could pull the upper cover in probably an hour.
Old Jun 18, 2007 | 01:31 PM
maxitech's Avatar
This is one of those jobs I hope never to have to repeat.
Old Jun 18, 2007 | 01:48 PM
Quickywd01's Avatar
What a P.I.T.A. So it would take another hour to put back on. This is going to take me all day I would think.
Old Jun 18, 2007 | 02:11 PM
Pervis Anathema's Avatar
When I did my '91 a few years ago, it was the bane of my existence.
Old Jun 18, 2007 | 02:32 PM
TWINTRBO's Avatar
I wouldn't bother, if its got 30K on it or maybe 40, you wouldn't be able to tell if it was changed or not, you could test tension though. I would pull the 5 top bolts, pry the cover away enough to see if you have a trapezoidal or rounded tooth belt, order the belt and do the change. Its really not hard to do just time consuming. Did anyone else have some really sharp welding slag on the frame right by the pulleys?
tsi6001
Oct 3, 2022 10:23 PM
kjlouis
Nov 24, 2018 06:09 AM
MatthewsMaxima
Sep 11, 2015 03:21 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
