please help. gauge face problem.
Old Jun 15, 2007 | 08:47 PM
'93maximaGXE's Avatar
yea, uh, i need some help with my gauge faces. i am trying to take the stock faces off. i got the mph/kph and the tach. faces off, i just need help on how to take the water temp. and gas face off. any advice is very appreciated.
Old Jun 18, 2007 | 06:02 AM
internetautomar's Avatar
mod or sell?
Why?
oh, and if you search you will find the answer
Old Jun 18, 2007 | 03:33 PM
traxtar944's Avatar
Would be lost w/out the org
good point, lol...why? BUT there are screws that you just remove to take everything off. The backside of the gauge face has double sided tape that you need to pull apart. Be carefull and watch for the needle stop so that you don't break it off.
Old Jun 19, 2007 | 10:46 PM
Loco7's Avatar
i did a write up on it a while ago check it out here http://www.cardomain.com/ride/2148645/7
Old Jun 20, 2007 | 08:52 AM
thanks. do you think i might find some se gauges at a junk yard? and i bought just gauge faces from import intelligence, here is a link to the faces.
http://importintelligence.com/FMPro?...dex.html&-Edit
and i have to take the stock faces off, run them under warm water, put them over the stock faces with some vinyl application fluid, then let them dry. the only reason i asked that question is because the gas and water face is glued to the plastic thing behind it, and i didnt want to take it off right away because there are no screws to hold it on like on the mph and tach. so. yea
Old Jun 20, 2007 | 01:39 PM
heresmymind
take a pair of wire cutters and wrap them around the needle and life up. the pin that holds them down will come up with them. when u put them on fill your gas tank up then push the pin back in. and put the temp gauge needle back in when you car has been sitting in the shade for awhile. then put the covor back on and the full set up
Old Jun 20, 2007 | 02:00 PM
MaximaN00b's Avatar
find an se at the junkyard and find se guages.
those guages you ordered look wrong.. unless a GXE redlines at 6k?
I thought it was 6500 like the SE.
And that speedo (on my se, would be telling lies.. the 105mph mark is where id be doing 115mph)
gxes guages are the same, just black?
Old Jun 20, 2007 | 02:03 PM
heresmymind
89-92 se gauges 125mph white
89-94 gxe 125 black
93-94 se 145 white
dont put 145 mph on the 125.
Old Jun 20, 2007 | 02:08 PM
MaximaN00b's Avatar
ok, gxe only goes to 125mph, se goes to 145mph.. so guess those are right for gxe.. my bad
did alittle searching
http://www.mimousa.com/home.asp?dir=...at=4&sub_id=25
they got some nice sets of guages.. 6 color glowing, reverse glow(whatever that is, but it looks awesome) think its a backlit glow it means.
expensive though
Old Jun 20, 2007 | 02:09 PM
MaximaN00b's Avatar
89-94 gxe 125 black
93-94 se 145 white
But do put the 125 on the 145
haha
do you know how fast you were going?
I HAVE NO IDEA OFFICER! 120 maybe?
OH and, 92 SE goes to 145mph, trust me, i should know. lol
Old Jun 20, 2007 | 06:08 PM
haha, ok. thanks guys.
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
