no power again but its not knock sensor this time
#42
injector readings came out fine. 12 and 13. blah blah . o2 sensor fixed. i think. there was a broken wire. fixed and code no longer appears. now just getting 55. so whats next forgot to mention if the engine dies and i try to restart it seems to not catch its idle and dies again. i have to give it a little gas and somewhat level it off myself
#44
Mooze:
I think this issue with your car has come down to one thing..Mechanical inexperience on your part..
Do not take this the wrong way as it is not intended to flame or gripe at you..
I Assume you done the k/s sensor replacement job yourself(correct me if i'm wrong),i believe you may have done something wrong in the process of the reintallation of the related parts after the k/s sensor job..
A few questions now..
1. did you replace the gaskets on the lower intake/plenum with new gaskets,or did you use gasket maker goop?(possible major intake manifold leak)
2. Did you reuse or replace the numerous vacuum lines on the intake plenum prior to reinstallation of the plenum(possible vacuum leak)
3. Do you have any corrosion(green looking crap) on your sensor/injector connections?
4. Does your car run/idle ok after unplugging the maf sensor?(be reminded your car will not rev over 2500rpm with it unplugged)
If you are close to the ashville,nc area,i will be in that area at the end of the week(thursday/friday) i will be glad to take a look at your car free of charge as long as you are close to this area.PM me if so..
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
#45
Originally Posted by MyGreenMax94
Mooze:
If you are close to the ashville,nc area,i will be in that area at the end of the week(thursday/friday) i will be glad to take a look at your car free of charge as long as you are close to this area.PM me if so..![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
2. all new vacuum lines
3. k/s had corrosion but i replaced and replaced harness so no corrosion
4. car dies after maf sensor is unplugged while running but will run if unplugged prior to cranking. not sure how far it goes up after being unplugged
#46
Originally Posted by mooze
1. all new gaskets
Did you torque the bolts on the lower intake manifold/plenum to fsm specs?
#48
If the intake manifold or plenum are leaking, you will hear it.
All the vacuum lines were replaced? Even the blow-by hoses, even the rear one where the rear plenum bolts attach? That one has a 90-degree bend that can crack and you may not see it.
Maybe the "vacuum tap for the heater water valve" is reversed?
#49
well i was at work when intake manifold was put down so im not sure my dad did it for me. im about 240 miles from asheville and my car is not close to getting on road
#50
i placed and torqued sensor/ placed manifold gaskets /throttle body gaskets /throttle body placement / vacuum lines/ plenum gasket/ torquing of plenum. fuel rails im not sure what else. in the process we changed exhaust manifold studs on both ends and gaskets k/n sensor and oil pressure thingy. im about to start tearing back down if u dont have anything else
#51
Did you check the ohm specs on the rear injectors?(requires removing the intake plenum)
#54
#55
injectors read fine. i cant really tell aobut the air leak thing cuz my cia sounds like its sucking the whole world. is that normal?
#56
Originally Posted by mikekantor
from post #31:
![](http://www.mikekantor.com/forums/EC-330.jpg)
I done this test when i had a intermitent dead miss,i couldn't come up with any useable numbers..But after removing the rear injectors i took a reading directly from the injector in question(#1) and found it to be waaay out of spec(infinite)..
So i stand by my "test them directly" method..
#57
http://s6.photobucket.com/albums/y21...=VIDEO_024.flv
there is link to intake the static noise is at idle just intake not engine
#58
So i stand by my "test them directly" method..![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Funny thing is that even if you pull the plenum and they all end up good, you'll have a new injector and put it away for next time... because sooner or later another will fail.
#59
No, that sounds bad. Try to isolate where the world is going into.
A cai on a ve makes alot of noise under the hood(sounds like a vaccum cleaner),so diagnosing an intake vacuum leak is quite difficult..
#62
Also,the noise from your setup is two fold of a true cai setup(filter in the fender well)
Get rid of it..
#63
Dude,that is not a cai,it is an HAI(hot air intake) IMHO these setups are completely useless as a performance mod(all they do is suck in hot air from the engine bay),your stock setup will give you more power vs the hai setup..
Get rid of it..
Get rid of it..
#67
Possible..Do you think the engine/injector grounds are not working/sub-standard?
#71
This should have been mentioned before, because it may not be obvious:
When you put the plenum back on, first tighten the vertical bolts lightly, then tighten the horizontal rear bolts lightly, just to make sure they all line up. Then torque all the vertical bolts, and only after that tighten the rear bolts.
#72
Also,it would be a good idea to tighten the bolts on the upper and lower intake manifolds according to fsm specs..
![](http://i10.tinypic.com/5znz4t3.jpg)
Torque specs are as follows
lower intake bolts = 14 ft/lbs(nuts on each end = 20 ft/lbs)
upper intake manifold collector = 16 ft/lbs(rear bolts=15 ft/lbs)
#73
? i have a torn insulator and the front insulators did not lift with the injectors as though they were not secured. i havnt gone past this point because i had to go to work. anyone thing this could be part of problem. another ? there is a metal hose that come frrom the bypass hose into the valve covers. the one under the plenum didnt seem to be all the way in. i didnt install that hose so im not sure
#74
Thats a blow-by hose, and its sort-of a very big deal
Those insulators dont always stay on when you lift the rails... why did you remove the rails? Anyway, put new ones in their place.
