Check Engine - code 32 HELP!!!!
Old Jun 18, 2007 | 11:12 AM
MAXI's Avatar
My Maxima has been throwing this CEL code 32 for a while now....but registration renewal is coming in August and for sure it will not pass.
i can reset the ECU but it keeps coming back after a few miles. ggrrrrr!
i already replaced the EGR valve, Checked the vacuum hoses for any disconneted hose. i also seafoamed this.
what else do i need to fix / replace? any help is greatly appreciated....
Old Jun 18, 2007 | 03:02 PM
Josh's Avatar
Since our cars are OBDI and not OBDII I doubt they will plug it in, they will probably just hook up an intake for the exhaust gases.
Edit: But you are from Cali so who knows...
Old Jun 19, 2007 | 09:02 AM
93SCMax's Avatar
98 SE
Code 32 is clearly EGR related
Did you replace the EGR with a new one or a used one?
If you disconnect the vacuum hose and rev up the engine, do you get vacuum?
Are you sure the vacuum hose is not clogged or does not have any leaks?
If the EGR is new, I'd also buy a new vacuum hose.
CorollaULEV
30
Aug 9, 2021 08:11 PM
magneto112
Sep 10, 2015 12:52 AM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
