Taillight problem
Old Jun 28, 2007 | 08:03 PM
bartown202's Avatar
Taillight problem
Hi, I`m a newbie ,want to say hi to everyone ,I am having a problem with my taillights ,I started the car turned on the headlights only to realize I had no front parking lights and no taillights ,but when I put my foot on the brakes the brake lamps came on and also the front parking lights came on ,I checked the fuse and replaced ,but the fuse blew again .
Old Jun 28, 2007 | 08:07 PM
Spacend's Avatar
You Definetly have a short somewhere, better get out the meter and start testing away
Old Jun 28, 2007 | 08:19 PM
Tquick's Avatar
I'll second that, certainly sounds like a short somewhere in the wiring. Look for damage to the harness somewhere. Did this just start happening? If so, have you done any work to the car at all recently?
Old Jun 28, 2007 | 09:20 PM
Greeny's Avatar
¯\(°_o)/¯
Check the rear tailight bulb sockets for corrosion. Very common problem on these cars..
Old Jun 29, 2007 | 08:50 AM
gapboi210's Avatar
The circuit boards in these cars at this age can be a common problem. The wires get old and break and sometimes it can cause the lights to do odd things becasue it is searching for a ground. Many of the older Altimas are prone to this too. If this is your problem, then this is what you need: http://cgi.ebay.com/ebaymotors/89-91...32724393QQrdZ1
Old Jun 29, 2007 | 11:22 AM
bartown202's Avatar
Thanks to everyone for their advice ,I will check these suggestions out.
Old Jun 29, 2007 | 02:57 PM
bartown202's Avatar
just changed Taillights
I just changed the taillights ,and we had some rain ,I think some water might have got in there ,where can I get some of the black goo that is around the taillights ,can I buy that at a local carparts store and what is the name of it.
Old Jun 29, 2007 | 03:10 PM
Greeny's Avatar
¯\(°_o)/¯
Window weld would work..
Old Jun 29, 2007 | 03:28 PM
bartown202's Avatar
Can I pick up at Auto Zone,Is this the stuff they install windsheilds with.
Old Jun 29, 2007 | 04:10 PM
Greeny's Avatar
¯\(°_o)/¯
Yes........
Old Jun 30, 2007 | 07:25 PM
bartown202's Avatar
problem fixed
I want to thank you guys for your advice ,I fixed the problem ,you see I just changed my taillights from GXE too SE so i used the circuit boards from my old taillights and used some window weld to seal up the opening. so thanks Gapboi210 and MyGreenMax94.
Old Jul 2, 2007 | 10:38 AM
bigalbert323's Avatar
yeah i got to do that too. I also had the same problem cause my back panell wire are bured out and i only use one bulb for each side for now. i got to order the panell.
Old Jul 2, 2007 | 11:45 AM
bartown202's Avatar
Just check post 5
If you check out post #5 you can order panel off of ebay ,nice looking max ,I like the rims.
Old Jul 4, 2007 | 11:38 AM
Quickywd01's Avatar
This same thing happened to me after I installed my new headunit so I thought that caused the problem. I just replaced the bulbs in the rear because the glass looked a little dark. Then I tried turning on the lights and the fuse for the tails blew. The bulb panel or circuit board looks fine. Does this still sound like the bulb circuit board is the problem?
Old Jul 4, 2007 | 11:45 AM
mooze's Avatar
boards are not always the problem. i dont know mine and i have 3 set of boards.
Old Jul 4, 2007 | 11:46 AM
Greeny's Avatar
¯\(°_o)/¯
This problem would probably be worth a trip to your local j-yard for a used unit test..
Old Jul 4, 2007 | 11:57 AM
Quickywd01's Avatar
I saw that there are three sets of wires and two have connectors. The third set goes behind the "carpet", does that also have a connector?
Old Jul 5, 2007 | 10:23 AM
Quickywd01's Avatar
The upper right bulb in the right side panel would not come out of it's socket. The black insulation in the rear of the socket is melted and after busting out the bulb everything in there was melted. Don't know exactly what happened but maybe since the bulb is really old it caused a problem. Should I replace the socket or the whole panel?
Old Jul 5, 2007 | 11:27 AM
Greeny's Avatar
¯\(°_o)/¯
I would replace the whole unit...
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
